Originally Posted by thebrandon
I noticed your note about the Timken 1960 seal. That is the one I used in the replacement. Maybe that is the problem. I wiped down the wheel to see if any more fluid would show up, it was a tiny pool, that I suppose could have formed from not cleaning everything well enough. I haven't seen it come back yet, but I may need to drive a bit to see if the pool forms again. Can't wait for the new seals to get here!
forget waiting to see it drip down the wheel. pop the ABS sensor and check that way. There is a pool of oil in there working its way through your bearing and out the other side. If this goes on too long the bearings will have been washed clean of all grease and they will fail in the near future. Did you read the entire thread and watch the video? If you don't get the seal on the retainer, it will leak again. It may require a trip to the machine shop to get the retainer moved.
And don't forget the obvious. Make sure the axle vent is open and free of any dirt.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family-->
I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
