Old 07-08-2012, 06:19 PM #16
mcaz5's Avatar
mcaz5 mcaz5 is offline
Real Name: Mikhail
mcaz5 is on a distinguished road
mcaz5's Avatar
Real Name: Mikhail
Originally Posted by DeTwizzle View Post
Definitely can't feel the tapping in the brake or the dash... you might want to look deeper into that!
I honestly would have no idea where to start. I'm not very mechanically inclined. Like I said its not an issue as of now, but you can hear it and feel it when I stop at red lights and stuff. Everything still runs and drives great.
-2001 Sport Edition 4runner 4x4 2nd gen Supercharged-
-1985 Toyota Hilux (Pickup) DLX Turbo - 4x4 5speed w/2LT Turbodiesel
Build Thread
mcaz5 is offline   Reply With QuoteReply With Quote
Old 07-08-2012, 08:52 PM #17
prospectator's Avatar
prospectator prospectator is offline
prospectator is on a distinguished road
It seems pretty random from what I can tell in the video. I know it's not a diesel but this noise is very common on all newer diesel engines after an oil change. And it's nothing to worry about. It has something to do with the engine harmonics.
I have a duramax and it makes the same random "typewriter click" noise after an oil change.
If you google search "diesel typewriter click" you'll see what I'm talking about.
I know it probably doesn't help, but it seems too random to be a lifter or injector, unless the injector is slowing dieing.
1997 SR5 V6 4X4, E-Locker, Total Chaos LT with Fox C/O and Fox 2.5 Bypass, LC 7.5 Wrap, LC TrekMaster shocks, 315/75R16 BFG KO2's on Limited wheels, 4:88 gears, Custom front bumper, Patco fabrications rear bumper, Patco fabrications custom rear arms
http://www.prospectator.com
prospectator is offline   Reply With QuoteReply With Quote
Old 07-09-2012, 12:07 AM #18
MadCityRich MadCityRich is offline
MadCityRich is on a distinguished road
My old '95 pickup's 3VZ engine had this sound. Sold it with 180k miles and zero operating issues.
My 2002 5VZ 4Runner has made this sound since I bought it. At 170k miles and 90k miles since I bought it, no issues.
I used a mechanic's stethoscope and the sound seemed to come from the power steering pump. Flushed the fluid this spring and it made no difference.
Sound disappears if I open the throttle. My guess is either something in the power steering pulley or maybe valve tick that just transmits to that area. Opening the throttle and getting some rpms might tighten something up a bit. Who knows.
My buddy's 4Runner (2001) has similar miles and doesn't make the sound at all.
No answers here, but I wouldn't sweat it unless it gets worse. [shrug]
MadCityRich
MadCityRich is offline   Reply With QuoteReply With Quote
Old 07-09-2012, 01:56 AM #19
4x4runner2002's Avatar
4x4runner2002 4x4runner2002 is offline
4x4runner2002 is on a distinguished road
i have a 2002 and i just did an oil change and now i have the same kinda tick. can't hear it in park but in drive or reverse i can hear it. it gets louder with the rpms and gets drowned out after 2000 rpms due to the motor. no power loss that i can tell not eating any kind of fluid from what I've been checking, just kinda annoying
4x4runner2002 is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 01:14 PM #20
caspermike caspermike is offline
caspermike is on a distinguished road
found out my ticking issue
So, had the same ticking sound as above, i also thought it was a valve train issue. As it turns out, today I blew a spark plug out, the same one I had to previously helicoil. The blown plug helicoil threads were still perfect, so my theory is that the combination of me not torqueing enough and a slight oil leak, the oil got in the threads and the plug worked itself out. That being said, the ticking noise must have been the sound of the plug firing further away from the cylinder as it kept back itself out. In the end, new helicoil, plug and ignition coil=engine running normal and no ticking noise.
caspermike is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 02:38 PM #21
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
I have a ticking noise too, and with a stethoscope I can pin point it to the #6 injector. However the rig runs perfect. Have run several bottles of techron throug it, no difference, so now just live with the noise....the "toyota tick". New plugs and wires did nothing for the noise. Compression is near perfect.
This spring I have to do timing belt and vc gaskets, so I might just go ahead and throw some rebuilt injectors in it while im at it. After all by then I should be at about 295k so they have seen some use. Last ones I did were from motorwest. Did them when I had a bad knock sensor. I bought their already done ones but now I have 6 spares right now and will send to them and have redone, they charge 20 per injector to test b4 adn after, clean , new seals and flow test print out. I think new seals are about half that per injector, so good deal I think. If you dont have spares or not time to send yours to them, then they do sell kits. They will also buy back your old ones when you are done swapping., well they used to anyway.
They also sell the fuel rail crush washers that you will need but not the fuel regulator o-ring.
no relationship to them, these were the guys mtbtim suggested in his video
Engine Misfire Diagnosis & Fuel Injector Replacement - YouTube
Injector Cleaning Service – MotorWest Performance
Old 01-26-2021, 04:47 PM #22
20 per? pretty good. I bought some rebuilt injectors a while ago when i thought my #4 was going, but new plugs/plug wires fixed the misfire issue for me. My point of my story is i immediately thought the worst (valvetrain, etc) when it exposed itself and was so simple. only had it a year and a half, 270,000 on it!
Ticking Noise cliffshow Problems & Warranty Issues 2 04-14-2011 03:45 PM
Ticking Noise when Cold? Ape Runner 3rd gen T4Rs 1 12-17-2010 03:49 PM
ticking noise shawgeorge11 3rd gen T4Rs 3 06-21-2006 11:50 PM
ticking noise escoastrider72 3rd gen T4Rs 3 03-20-2006 08:29 PM
03 4runner ticking noise (lifter noise) jgball Problems & Warranty Issues 1 12-18-2003 12:49 PM
