03-10-2019, 07:57 PM
#46
Official Vendor
Official Vendor
Originally Posted by RyanNapoleon
I've swapped my bezel out. It's really not that hard at all, it just takes a bit of time. The trick to getting the window motor unbolted from the window itself is to roll down the window a few inches until you have clear access to each bolt. Besides that it's straightforward
Who wants to help me do it and is close to PA????
For 4Runner/SUV Accessories, please visit www.burtmanindustries.com
My 4Runner website
https://www.youtube.com/user/burtmanindustries, New YouTube channel! please subscribe and I'll make more videos!
[email protected]
DO NOT PM - text/call 717-319-2100 (24/7)
03-11-2019, 07:56 PM
#47
Real Name: 3 Bears
Real Name: 3 Bears
for some reason I thought you lived in the Corvallis Oregon area
03-12-2019, 09:39 AM
#48
Real Name: John
Real Name: John
Where are you in PA?
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
03-16-2019, 01:07 PM
#49
Originally Posted by thegipper
this happened to me. when you take off the two bolts that hold the latch mechanism on the inside you typically let it drop and ignore it. Be careful putting the latch mechanism back on because you have a 50% chance of putting it on upside down and if you do the handle on the outside will not work. There is a little plastic piece on handle that pushes down on the inside mechanism. test this before you put it back together and slam it closed. it's a PITA to solve if this happens
2000 SR5 Sport 4Runner 4x4 5vze w/5 speed manual
Millennial Silver paint. Moon roof, Cloth Moon Mist interior
Still stock but not for long
03-17-2019, 11:24 AM
#50
Originally Posted by Johnny0
...you have a 50% chance of putting it on upside down and if you do the handle on the outside will not work....
Ha! I did exactly that. Had to pull the cover from inside with the tailgate shut, pop the latch release by pulling the cable and take it apart again.
2002 SR5 Sport Edition; Thundercloud; All Stock.
06-13-2021, 08:49 PM
#51
Real Name: Doug
Real Name: Doug
Rear handle has more or less stopped working
So, the rear handle started getting sticky a while back. Its now at a point where its become a PITA to open the hatch. I bit the bullet and ordered a new latch assembly and handle. Luckily, everything inside the hatch is rust free except where the latch assembly bolts in. I'll treat(Corroseal) that before I put it back together. So, at this point I just want to replace the handle. Do I need to remove the outside license plate bezel to do this? I appears that maybe I do, as there are little tabs on the handle frame----maybe for the plate light lenses?? After reading this thread, maybe I should have ordered a bezel (garish) foam gasket....?? Any input from someone who has done this would be appreciated!
Thanks in advance
1998 SR5 3.4L V6 Auto... Pretty much bone stock...aside from the Tundra brakes, OME880 and OME906's in back all with Rancho 9000XL adjustable shocks ... "Livin' the dream in the Canadian Okanagan!"
Electronics/Telecommunications Engineering Technologist
06-14-2021, 01:14 PM
#52
Real Name: Andy ಠ_ಠ
Real Name: Andy ಠ_ಠ
Thanks in advance
just did this work myself see posts in build
https://www.toyota-4runner.org/3641622-post297.html
https://www.toyota-4runner.org/3641931-post298.html
yes get the weather strip, it will keep the water and junk out. you will probably want to take the bezel all the way off, IMO it's easier but others may have tricks I could not figure out. since I was repainting mine I took it all off.
I would also get the clips(7681789101) and pads for the garnish because you are probably going to rekt the old ones getting them off. just be super careful because the plastic is discontinued and the only source for them now is junk yards.
06-15-2021, 09:04 PM
#53
Real Name: Doug
Real Name: Doug
Thanks for the answer!
I appreciate your advice on this. I will order the pads (is there more than one??) AND thanks for including the part number for the clips! I will follow your advice!!
06-15-2021, 09:21 PM
#54
Bezel is still available. Part #76801-35260. This is I think for 99-01. Then 02 has some other ones.
1999 Limited with rear locker.
Sherpa Matterhorn | Sonoran Steel Diff Drop | SPC UCAs | DuroBumps Front and Rear | OME 890 Springs and Black Tokico Shocks | Eimkeith Reinforcements and PCK | King Coilovers | OCD Sway Bar Links | Opt Offroad Rear Arms | Lil Skips Gas Tank Skid Plate | FGP Rock Sliders | 4x Innovations Rear Plate Bumper with tire carrier
06-16-2021, 09:02 AM
#55
Real Name: Andy ಠ_ಠ
Real Name: Andy ಠ_ಠ
your correct I think there is a different part for each year.
each place I tried let me order it then reply back and say it's unavailable.
for 98
76801-35160 - Finish Panel - 1996-1998 Toyota 4Runner | World Toyota Scion Parts
for 99+
76801-35260 - Finish Panel - 1999-2001 Toyota 4Runner | World Toyota Scion Parts
I have a 1998 and 2000
I measured the 2000 and the later years are a bit bigger in size... so.... I guess I would have to see them side by side to figure out if they could interchange based on the mounting points. I can't imagine they moved stuff?
looks like the new ones for 99-2000 don't come with the badge and that is fine by me hmmm darn there goes my money again.
12-29-2021, 05:10 PM
#57
Many thanks to everyone who contributed to this thread.
I just finished painting and refurbishing a bezel I pulled from a junkyard.
I used Rust-oleum Flat Soft Iron, followed by Satin Clear Enamel.
We also installed a rear backup backup camera while we were at it.
It took several hours to complete, but I'm happy with the results.
12-30-2021, 08:41 AM
#58
Installed my original 96-98 back on the other day. The chrome 02 bezel didn't cut it for me any more.
Did it with hatch open. Propped the black metal plate. Kept rear window closed. Used a 12" long skinny 1/4" drive- which is perfect for removing all 10mm nuts and plastic clips (press an rotate) Took about an hour. Don't mess with window mechanism or hatch handle- let in rest insitu.
Debadged the rear hatch leaving 4Runner one on bezel only. So much cleaner looking.
One thing, as I went from the larger later bezel to original smaller one I have a faint tide mark.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
