11-12-2018, 04:14 PM
#271
NEw to forums, what did you do for shock locations?? I want to do the leaf swap to my 97 e locked. Do I need offset shocks like silverados or 1st gen runners for example, one forward one backward? Or can I keep stock locations both on rear of axle
09-23-2019, 08:09 PM
#272
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc's ZRV(Pic Heavy)
Picked up a Lefty. Just need to order plates and a top-shift kit.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
09-27-2019, 09:37 PM
#273
Uh oh.......
09-28-2019, 04:47 AM
#274
very nice
01-07-2020, 11:33 PM
#275
01-12-2020, 12:59 AM
#277
03-17-2020, 09:28 AM
#278
Between the craziness that has been going on at work lately, and the fact that I can’t sleep when I get out of work, I knocked out a dual Jerry can mount.
@ Bandit Runner
, I took some artistic liberties with the design, hope you don’t mind. I still need to get you those roof rack designs.
Got the 3/16 diamond plate from the scrap bin at my local
Yard, and the ‘cover’ is 1/8”x1.5” from Home Depot.
https://www.youtube.com/watch?v=Op9kgCp5ajo&feature=youtu.be
03-17-2020, 11:17 AM
#279
Looks great Doc! The hinge and latch are exactly how I figured they would work.
Bandit Runner, 2021 TRD Off Road Premium
Build Thread: https://www.toyota-4runner.org/5th-g...ild-2-0-a.html
06-02-2020, 09:15 PM
#280
Picked up a 96 5 speed.
Time for the swap.
06-03-2020, 09:17 AM
#281
Real Name: Werner
Real Name: Werner
Time for the swap.
are you doing a write up on the swap? Im about to do mine here pretty soon so I will follow this. Moreso wiring. Ive got a 2000 SR5 swapping in a 2000 trans/ecu from another SR5
The dunes got boring because I couldn't jump. I'm not the type to enjoy someone else's vehicle. So i'm in the process of making making the dunes no longer boring. I guess that involves jumping.... A lot.
06-03-2020, 03:29 PM
#282
Yours will be easy.
Honestly, if it’s all the same climate controls; I’d just swap everything over.
This is a 96 5 speed going into a ‘99 Limited; so my wiring process probably isn’t going to help you a whole lot.
06-04-2020, 08:34 AM
#283
Real Name: Werner
Real Name: Werner
Yours will be easy.
I was thinking of that because I have the entire harness and everything. Theoretically if I swap that harness from there on its just plug and play im pretty certain. At any rate, nice to see another manual getting its usage!
EDIT: here are all the part numbers I could find that toyota still stocked for the m/t. I was planning on a possible rebuild at least with new bearings and seals so I dug this up a couple months back. Figured i'd post them here if you needed a reference number for anything!
Clutch Pilot Bearing (90363-12024) $5.41
M/T Output Shaft Bearing, Rear(90363-30075) $16.04
M/T Output Shaft Bearing, Front(90363-35078) $46.14
M/T Input Shaft Bearing(90363-40034) $51.36
M/T Counter-shaft Bearing, Front(90365-25019) $65.11
M/T Counter-shaft Bearing, Rear(90365-34005) $33.08
Manual Transmission Input Shaft Seal (90311-32012) $8.15
EDIT #2: Prices are all from Conicelli Toyota
09-23-2020, 03:24 AM
#284
Parts are finally starting to roll in.
Autel MX808 (been wanting a new scanner for a while. )
Mechanical to Electrical VSS
TB/WP kit
Spanner for Icons
Twin stick boot
LCA bushings
Terminal Pin tool
MTM survivor can
45° elbow.
Just got to wait on the rest of it to show up.
09-23-2020, 06:22 PM
#285
Real Name: John
Real Name: John
Hey I know what the survival can is for lol!
Sent from my SM-G986U using Tapatalk
98 Toyota 4runner 3rz 5spd 4x4 - Sold Build Thread
06 4runner 2uz Build Build Thread
Instagram: @Kryptowerkz
