Old 04-13-2022, 09:37 AM #31
audiness's Avatar
audiness audiness is offline
audiness will become famous soon enough
audiness's Avatar
I have a perfect working order never-strawberry-milkshaked trans for sale in the classifieds. w /159k miles
FS: 1999 or 2000 Automatic Transmission and Transfer case - Charleston,SC
audiness is offline   Reply With QuoteReply With Quote
Old 04-13-2022, 01:09 PM #32
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Originally Posted by Bad Luck View Post
Completely missed the question. My bad! Only the 99-00 Limiteds use the push button. They have the VF3AM transfer case, and the SR5/base have the normal VF2A transfer case.
Thanks! So I don't need to worry about which 99/00 transmission I source as long as it's a CA 4X4 it'll bolt up to my TC?
Old 04-13-2022, 01:17 PM #33
Real Name: Blair
Real Name: Blair
That's tempting. It would be much nicer to buy from someone with a more transparent history like this one has. Did you remove the transmission with the TC attached, and if so, can it be reinstalled in the same manner? Cross-country freight with diesel prices might be rough.....
Edit - to clarify...I'm still thinking ahead. i don't have a reliable diagnosis yet and am still driving daily out of necessity.
Old 04-13-2022, 02:12 PM #34
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Correct. Any 4wd 99-00 transmission will bolt up to your transfer case. The VF2A (standard j-shift) and VF3AM (multimode) have the same bolt patterns/etc and will interchange to any 96-02 4wd 4Runner transmission.
To answer your other question above, you can remove transmission and transfer case as one unit or you can separate the two to make it less cumbersome. If you are having to keep your current transfer case I would separate the 2 while it's in the truck, but if you decide to keep them together remove the bottom 3 transfer case to transmission nuts so they won't be blocked when you have it all on the ground after removal.
Old 04-13-2022, 07:19 PM #35
If you are comfortable swapping the transfer case and pan/dipstick tube, any 4WD transmission from '96-'00 is compatible with your truck. You probably don't even need to swap the pan... I have a '97 fed emissions transmission (including dipstick) on my '99 CA emissions truck. They are different internally (valve body) but are compatible externally.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-13-2022, 07:47 PM #36
Real Name: Blair
Real Name: Blair
Thanks I'll keep that in mind. I figured there was a good deal of crossover. I just want to keep it as simple and straight-forward as possible because I will screw something up given the opportunity! Too bad (and bless them in the same breath) Timmy and Sean already did an R & R transmission video....I don't live too far from them (until Tim moves).
Anyone had their transmission rebuilt? laureena23 3rd gen T4Rs 7 08-16-2011 09:04 PM
New Rebuilt transmission never installed vaneck34 Classifieds - buy & sell (no commercial ads please) 0 06-26-2007 10:16 AM
New rebuilt transmission for sale vaneck34 Classifieds - buy & sell (no commercial ads please) 0 06-10-2007 02:44 PM
New rebuilt transmission vaneck34 Classifieds - buy & sell (no commercial ads please) 0 06-10-2007 02:41 PM
Rebuilt Transmission scotty208 Maintenance/Detailing 1 11-24-2006 04:50 PM
