09-13-2012, 03:02 PM
#46
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
You have the only wheels I would consider getting rid of my lx450 wheels for. That or for some Trail Ready HD beadlocks. Good looking 4Runner man!
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
09-13-2012, 03:14 PM
#47
Thanks for the compliment. I have liked these wheels ever since my friend Drew got them on his 06 prerunner.
I have some 16x8" Hutchinson Border Patrol double beadlocks with added 3/8" rock rings waiting to go on when the new axles get put underneath last next year.
Figured the Racelines are a good wheel to tide me over till then.
Todd:
1997 4runner limited - crawling/camping
http://www.toyota-4runner.org/3rd-ge...ner-build.html
09-13-2012, 03:27 PM
#48
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
Are yours 16's or 17's? If I haven't gotten some a different wheels by the time you're ready to get rid of them, and you'll ship, I want them haha.
09-13-2012, 03:34 PM
#49
I'll hold you too that.... hahaha
I may be able to swing that. I still have the boxes so it would be an easy ship option. They are 16x8" 4.5 BS. They ended up being the perfect offset because i rub a little on the frame at full lock in the rear and on the pounded firewall and rear of the front fenders a little with the 305/70/16's. Any more either way and it would have been even worse trying to get them to fit with just a 1.5" topout spacer lift.
and I meant late next year. My tow rig will be getting swapped out from my 06 runner to a 97 Powerstroke after the wedding when my fiance gets another car. Looking for another set of the hutchinsons for that one so I can run the MTR's on there with the E load rating.
Todd:
09-13-2012, 04:13 PM
#50
Real Name: Drew
Real Name: Drew
Originally Posted by crazydubman
I'm ordering up the cooler tomorrow. Going with a B&M 70266 from Jegs. Figure I will be into the whole setup about $100. I want it taken care of before Pismo. Bumpers come next week so I can take care of the cooler at the same time while the front end is apart and easily accessable.
Should be ordering up the Poly steering rack bushings as well through Wheelers to get that taken care of also.
Damn i just got the bumper and sliders done.. that was about all my spending money. the rest is for the trips!
1996 Limited 4x4 A/T. My first car. Built and SOLD at 215k.
2000 Limited 4x4 A/T. College ride. Built and SOLD at 240k.
2000 SR5 4x4 5 Speed. Third times the charm. Bought at 298k from under a tree.
09-13-2012, 04:18 PM
#51
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
I believe my current wheels are the same specs, so no problems there. We'll see if I have the same wheels let alone the same truck by then. Anything is possible lol.
09-13-2012, 04:33 PM
#52
Haha very true. I thought i was keeping my 88 and now look what happened
Todd:
09-13-2012, 04:35 PM
#53
No worries at all. I just need to get these two things taken care of before i go.
Todd:
09-13-2012, 04:46 PM
#54
Real Name: Drew
Real Name: Drew
cool. let me know if you need some help.
09-21-2012, 05:35 PM
#55
Bumpers and poly steering rack bushings arrived today.
Should have some pictures in a couple hours when I get home and start prepping them for paint.
So far they look great. need to figure out the lighting, CB antenna, and flag mount tabs hopefully before paint. Need to stop by Any7offroad to see whether I can weld on the tabs real quick.
Bumpers will get mounted this weekend along with the winch, trans cooler, and hopefully wire up the fog lights.
Also,
Firestick II 4ft whip, spring mount, and fire ring 18' coax cable should be here Monday.
Todd:
09-21-2012, 06:01 PM
#56
Sounds like a fun weekend! I've been eyeing the poly bushings too since I'm sure mine are shot. Post up your thoughts after the install.
'99 Ltd 4x2
Some welders
09-21-2012, 06:10 PM
#57
Will do Josh,
I'm hoping it helps out but im thinking that when I change them out I will feel a lot more of the out of balance tires from everytime i air down hahaha......
Still looking at picking up one of your racks at some point. just need to get a few other items addressed firs.
Bumpers should be fun for sure. Will be good to finally be able to get my winch and lights back on a vehicle and off my garage floor. Plus with Pismo next weekend the CB setup, flag mount, and lights will be essential.
Todd:
09-24-2012, 12:32 AM
#60
Well bumpers are painted and installed. I should have pictures tomorrow afternoon when I get home from work. my phone froze and now won't start so I'm heading to verizon tomorrow after work. Hence the no pictures yet.
Got the winch installed and powered along with the fairlead and synthinch line, grill cut for the winch, worked on trying to locate placement of the trans cooler, and cleaned up some of the sheet metal behind the new tubes.
Front bumper/ crossmember needs some finesse as it seems like it is leaning forward just a tad causing contact on the drivers side fender flair. Its just a tiny be but enough to bug me. Hoping to see whether I can shim the crossmember from underneath to help it tilt back some.
Fog light tabs got welded up and lights mounted. Should be welding up the hella 500 tabs for the stinger this week along with a lop in the top center to have for a winch hook point. (Don't want it down where the factory hook points are cause I have make contact on a number of occasions with those tabs
Should have the CB antenna and coax tomorrow. Hopefully I will get a chance to run the coax back for the antenna and the power leads for the receiver.
Lots to do this week before pismo for sure.
Todd:
