Well sorry for the lax picture updates.
Hopefully these will make up for that
Bumpers painted and mounted - Check (need to fine tune the alignment on the front... May need to shim the crossmember from the bottom to tilt it back some)
winch and 100 ft synthetic line mounted - Check
Aluminum fairlead - Check
100W Hella Micro DE projector fogs - Check
CB antenna and Coax cable mounted - Check
Flag mount - Check
Still to do:
100W Hella 500's and light tabs
CB wired up and powered
Trans cooler
switches in dash for lighting
fuse block for all extra power needs
Sliders welded up
Rock lights mounted and wired
Whitson metalworks roof rack
install raingler cargo restraint netting
Storage racking for cargo area
There is probably more, but thats a good start hahaha.
