Old 07-30-2012, 12:32 AM #1
4-Ripcord's Avatar
4-Ripcord 4-Ripcord is offline
Real Name: Jim
4-Ripcord will become famous soon enough 4-Ripcord will become famous soon enough
4-Ripcord's Avatar
Real Name: Jim
Broken Driveshaft, snapped shocks, bent links, etc..
Went offroading today and the run had to get cut a little short..
Was attempting to climb a steep rocky/sandy/steps hill, About 3/4 of the way up the truck starts to jump around and before I can settle it I hear a very loud POP!
I looked to my spotter and said.. "that.. did not sound good"
We all went to look under the truck and we didnt see anything out of the ordinary, although we knew something was wrong. All the links were intact and strait, no broken CV axles, no leaking fluids anywhere.. hmm
I went to back down and after 2 feet I felt/heard another VERY LOUD series of pops.
Stop the truck again and get out to look, what do I see this time? Both rear shock shafts are sticking out of the boots.. broken. The rear differential is pointing up in towards the bottom of the truck.. one upper control arm link is destroyed and the other had the bolts sheared off..
After looking at it a while, I was able to determine what happened.
The driveshaft snapped while the axle was drooped and was pretty far out of the slip yoke. When I went to go back down, the shaft was seized in that position and the slip yoke was now unable to take up the excess length and so instead the axle shifted up like it did to allow the suspension to compress again. When the axle shifted up, the upper control arms snapped being that the OEM ones are so thin, and the shocks just did not stand a chance against that.
So.. parts that were broken:
Rear driveshaft
one of the rear upper control arms (the bolt just sheared on the other one)
Both rear shocks
'13 Tacoma TRD-OR: The Spruce Goose. BUILD
'02 Sport Ed.- V2.0: The better build. Totaled BUILD 2.0
'02 Sport Ed.- V1.0: The college build Sold BUILD
4-Ripcord is offline   Reply With QuoteReply With Quote
Old 07-30-2012, 12:38 AM #2
Stick Figure's Avatar
Stick Figure Stick Figure is offline
Stick Figure will become famous soon enough
OUCH ... on the plus side at least it should be a fairly simple remove and replace the broken parts kind of repair.
Stick Figure is offline   Reply With QuoteReply With Quote
Old 07-30-2012, 12:39 AM #3
4-Ripcord's Avatar
Real Name: Jim
4-Ripcord's Avatar
Real Name: Jim
Apart from the upper control arm mount that was mangled, yeah it should be a bolt on repair.
Old 07-30-2012, 12:43 AM #4
momo.75's Avatar
momo.75 momo.75 is offline
Registered User
Real Name: Morris
momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of
Registered User
momo.75's Avatar
Real Name: Morris
Holy ****e! Sorry man
momo.75 Build ThreadClick to order T4R.ORG Decals • @urban_overland
momo.75 is offline   Reply With QuoteReply With Quote
Old 07-30-2012, 12:43 AM #5
BigFishAllDay's Avatar
BigFishAllDay BigFishAllDay is offline
BigFishAllDay has a spectacular aura about BigFishAllDay has a spectacular aura about BigFishAllDay has a spectacular aura about
Damn, Jim. I guess that means you didn't make it to work on time today?
Seriously though, what's up w/your 4Runner? Did you have to leave it out there?
2001 SR5 Sport Ed. S/C'd V6 Auto 4wd (< Click for Build) ....everything but a kitchen sink (it's on the "to do" list)....
2003 Tacoma SR5 S/C'd V6 5-spd 4wd (< Click for Build) ....boost, armor, lockers, gears, etc....
2008 Sport Ed V6 Auto 4WD (< Click for Build) ....the Grocery Getter OEM+ build....
My Write ups: T-Case Leak? - 231mm TBU - Rear Axle Seals - Trans. Cooler Install - Suped Up Air Comp - Big 3
BigFishAllDay is offline   Reply With QuoteReply With Quote
Old 07-30-2012, 12:46 AM #6
4-Ripcord's Avatar
Real Name: Jim
4-Ripcord's Avatar
Real Name: Jim
I was only 20 mins late
We got the rear driveshaft unbolted and removed which allowed the axle to go back to the normal position. Then we got the one remaining upper control arm secured as much as we could and we drove out really slow. I had to drive through town in 4wd Hi using just the front wheels.. Luckily my family has an extra vehicle so I have some time to get it fixed.
BTW driving without rear shocks is an awesome experience. I would stop at a stop light and people would look at my truck bobbing up and down thinking I had Hydraulics or something, lol.
Old 07-30-2012, 12:50 AM #7
4Running Daily's Avatar
4Running Daily 4Running Daily is offline
Real Name: Connor
4Running Daily will become famous soon enough
Real Name: Connor
Holy Crap!
Good luck with the repair, get this beast back on the road!
On a serious note:
When you get a new driveshaft, make sure you color match it, it'll make it stronger.
1996 Toyota 4Runner 4x4 w/ 5 speed- Lifted, Locked,Painted,Armored
Build: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Originally Posted by invisible4Runner View Post
Highlander = minivan, purses, soccer practice
4Runner = testosterone, steak, dirt
4Running Daily is offline   Reply With QuoteReply With Quote
Old 07-30-2012, 12:51 AM #8
Whew!!! I'm releived you didn't leave your rig out there man. You probably would not have been happy with what you came back to.
The 4Runner @ U-Pull it still had the upper links last time I was over there, in case you're interested.
Let me know if you'd like a hand with anything. I'm off 8/6-8/10.
Old 07-30-2012, 01:10 AM #9
4-Ripcord's Avatar
Real Name: Jim
4-Ripcord's Avatar
Real Name: Jim
Originally Posted by 4Running Daily View Post
On a serious note:
lol wut
Actually I am convinced it makes things weaker now.. My front bumper is mangled quite a bit from today as well. But ill post more on that when I have a chance to talk with the dumbass who built it.
You and me both, I would have stayed with it overnight If I had to..
Thanks for the heads up about the U-pull It 4runner, I totally forgot about that one. Ill be there in the morning!
EDIT: the links were taken..
Old 07-30-2012, 05:43 AM #10
thor999 thor999 is offline
thor999 is on a distinguished road
Friend of mine once had an old (milk truck?) that had no shocks, and even better, no seats either :0 he bungied down some milk crates for seats haha he also had an old Jeep with absolutely no brakes. Both were very fun to drive off road
thor999 is offline   Reply With QuoteReply With Quote
Old 07-30-2012, 09:04 AM #11
AZTOY's Avatar
AZTOY AZTOY is offline
AZTOY is on a distinguished road
AZTOY's Avatar
WOW! What a mess. Good luck with the repairs.
97 V6 4X4 AT; ICON 2.5 EXT TRAVEL COILOVERS / SS 1.2 REAR; AUSSIE LOCKER; TC UCAs; SAVAGE OFFROAD SLIDERS AND SKID PLATES; ARB BUMPER; WARN WINCH; LOTUS CONTROL ARM SKIDS; DECKPLATE/ISR; 265/75/16 BFG KM2
AZTOY is offline   Reply With QuoteReply With Quote
Old 07-30-2012, 09:14 AM #12
BrianSD_42's Avatar
BrianSD_42 BrianSD_42 is offline
Real Name: Instagram: briansd_97r
BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice
BrianSD_42's Avatar
Why did the drive shaft snap? I read the explanation for what happened afterwards but I am wondering why the first failure occurred. You seem the type not to abuse the truck.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
BrianSD_42 is offline   Reply With QuoteReply With Quote
Old 07-30-2012, 09:23 AM #13
farmerjon's Avatar
farmerjon farmerjon is offline
farmerjon is on a distinguished road
farmerjon's Avatar
hahahahaha! I broke my rear driver's side shock and it really bobbed all over the place, I felt each bump three times or more! Fun haha
And sorry to hear about this mess - get 'er fixed and back on the trails!
1998 T4R SR5 Natural White 4WD 5VZ-FE-V6-3.4L / ARB / Subaru-Hilux Gauge Pack / 199mm TBU / BFG All-Terrain KO2 265/70/R16
Build Thread. T4R & adventure photolog.
farmerjon is offline   Reply With QuoteReply With Quote
Old 07-30-2012, 09:52 AM #14
JWaldz's Avatar
JWaldz JWaldz is offline
Moderator
Real Name: Waldo
JWaldz is a jewel in the rough JWaldz is a jewel in the rough JWaldz is a jewel in the rough
Moderator
JWaldz's Avatar
Real Name: Waldo
Now we be a good time for duals and a freshly built shortened & stroger driveshaft
Glad it wasn't worse. Just because it didn't break doesn't mean it's not on the verge of breaking. Better check everything under there twice. Hope I don't ever do that lol. Good luck!
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
Sponsors: Coastal OR | Extreme LED | SherpaEC | Overland GG
3G Build: ShowGirl | Instagram: ^Click Above^ | FB Page: JWaldz4R | T4R Mod: Contact Me
JWaldz is offline   Reply With QuoteReply With Quote
Old 07-30-2012, 10:06 AM #15
the great him's Avatar
the great him the great him is offline
Real Name: Isaac
the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all
Real Name: Isaac
damn man... i saw the pics on the book but i just thought you got on it a little hard with the SC and split your shaft... wow man that blows
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
http://www.metaltech4x4.com/
the great him is offline   Reply With QuoteReply With Quote
Broken sway bar end links (PICS) Bill_Dunnigan 3rd gen T4Rs 37 07-11-2016 10:50 PM
Broken Rear Shocks - What should I get? farmerjon 3rd gen T4Rs 11 06-25-2012 01:47 PM
Replacing shocks, bilsteins ok? maybe 2"lift, ALSO driveshaft clunking?. HELP spitvenom 3rd gen T4Rs 24 05-04-2012 10:31 PM
Are links broken? GrantK 5th gen T4Rs 4 03-25-2012 08:20 PM
Video of Driveshaft - Bent or bad U joint? jmrwd3 3rd gen T4Rs 6 04-06-2009 10:57 AM
