08-01-2012, 01:23 AM
valve cover gasket question.. loose bolts?
Hey guys, I noticed I had some oil leaking from my valve covers, I washed the side of the motor to keep an eye on it and it started leaking and i can smell oil burning on the surface of the motor. So I did a bit of research and found out how to replace them but I read about so many people having the bolts loose and causing a leak..
so I went out this afternoon and looked at mine, and ALL of them were loose to the point that they could be tightened by hand.. why is it that the bolts loosen up? It kind of scares me about what else could loosen up without me knowing..
08-01-2012, 01:29 AM
Hey there 95bb2, another thread recently popped up regarding this same issue. I posted a couple of links on it, and I'm feeling too lazy to post them again. Just read through a few responses. The VC bolts need to be torqued, but I can't remember the specs. Be careful with them as well, cuz they can be nasty if stripped.
Valve cover gaskets
Oh, and if you're worried about anything else, I'd take a quick look at the 3rd Gen Buyer's Guide if you haven't done so yet. It addresses some issues that Runners are known to have. It's a sticky at the top of the forum. Good luck.
97 SR5 4x4 (136,000 k) SS Lifted, 33s, Designing my own armor, Slowest jet fighter in the world (Yes I like toggle switches)
JasetheDamager's Build/Upgrade/Noob/Obvious Questions Thread: http://www.toyota-4runner.org/3rd-ge...7-sr5-4x4.html0
08-01-2012, 01:40 AM
I was wondering why they loosen up as well. My hypothesis is that you first tighten the bolts, but after the engine has it's heat up and cool down cycle for a little while the rubber on the washers breaks down a little and then you end up with loose bolts. Either way though, you just need to tighten them back up again. If it's not too bad on the driver's side I would just tighten the lower 4 bolts. It's a bit of a PITA removing the intake manifold for the upper 4 bolts.
97 SR5 5 speed, 285/75/16 Duratracs, adjustable 3" Toytec coilovers, 8 wrap LC coils and 5125 Bilstein shocks, Addicted Offroad bumper, M8000 winch, Addicted Offroad rock sliders
08-01-2012, 02:02 AM
Yeah don't over tighten them. Found that out the hard way and cracked the valve cover.
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
08-01-2012, 03:44 AM
I checked earlier to see if mine were loose and they were all snug but still oil leaking pretty bad. New seals are like 250-350 from what iv seen.
But yours may have loosened so much maybe from heat and pressure on them? I was thinking it could be something like that causing them to just get loose from over time, something like what scottyb said
3.4 Swap. Sas. Locked front/rear. 5:29's 35x1250 KM2's
08-01-2012, 09:15 AM
thanks for all the info, I didn't have the correct specs so i tightened them very carefully so they wouldn't snap or break.
Valve cover gaskets
and I went through that guide up and down like 299 times before i bought the car lol and even after, so I checked all of that out thank you! I'll look for the other thread and see whats up with the links
08-04-2012, 02:45 PM
So how tight should they be?
E-Locker, Bilstein 5100,LX 450 Coils, Tundra Wheels Graphite, 33'' Duratracs, 1.5" wheel Spacers, Energy Suspension Sway Bar Links and bushings,Roll Bar, LED's, Sport Hood! XRC 9.5k Comp Winch Custom Mounted, 3rd Row Rumble Seat, B&M Tranny Cooler, Tundra Brakes, 4XInnovations Sliders, Uniden 520XL Pro CB, 4' Firestik.
My Build Thread!!
http://www.toyota-4runner.org/3rd-ge...8-limited.html
08-04-2012, 03:02 PM
Real Name: Adam
Real Name: Adam
I did mine snug, then additional 1/4 turn. That was when I first got it and it's been fine ever since. I'm not sure of the torque specs.
08-04-2012, 03:16 PM
Real Name: Eric
Real Name: Eric
every 5vzfe i've worked on all have loose valve cover gasket bolts, and 90% of the time you just have to tighten them down (loctite wont work cuz of the heat) but the problen is you can only tighten the out side 8 bolts, cuz the inside are covered by the intake plenum. it is a PITA job to replace gasket, about 2-4 hours if you never done it b4.
08-04-2012, 03:25 PM
2-4 hours isn't much for a job like that considering were mostly shade tree mechanics.
My Build Thread!!
08-04-2012, 03:30 PM
WasaaQaaxs.SSSxz
My Build Thread!!
08-04-2012, 03:33 PM
Real Name: Eric
Real Name: Eric
the first time i did mine i took it super slow tagging all vacuum hoses, cleaning everything, i think the job took 8 hours, but i did couple after that for few member on the forum and it took about 30 mins, so thats how easy the job is if you done it b4.
08-07-2012, 08:47 PM
WasaaQaaxs.SSSxz
Just noticed this. Must have been my three year old posting. Haha
My Build Thread!!
08-07-2012, 09:12 PM
the stealership mentioned i should replace my vc gaskets I checked them the other day while replacing my spark plugs and sure enough they were all finger loose. I gave them all a little tightening not too much will see if this works...
08-08-2012, 07:00 AM
I tightened mine down this past weekend as well. Will check them again soon.
My Build Thread!!
