I would use OEM. I use shoptrd.com usually because they are about 40% off the stealership price
'99 Limited, Millennium Silver, E-Locker
Front: '99 Tall Springs, Tundra Bilstein 5100's @ 5th perch, 3/8 in. Top plate spacer, Light Racing/SPC UCA's, 1.25in wheel spacers, sway end links from 2nd gen rear
Rear: Toytec Superflex, 05'+ Tacoma Bilstein 5100's, extended bump stops, extended brake line, e-brake strain relief bracket, 1.25in wheel spacers, front sway bar links, ES sway bushings
Other stuff: 1/2" body lift, B&M tranny cooler, extended rear diff breather, deckplate, blue-wire mod, ARB Tacoma BullBar, Smittybuilt XRC8 winch, 285/75/16's
