Originally Posted by JimG
I had the same problem with my '99 when I got it, at the time I looked up how to fix it and it was around $1000 or more just for the parts (the entire dash cluster needs to be replaced) so I figured using the odometer to keep track wasn't that bad after all.
Due to a totaly unrelated problem with sparkplug blowing out and damaging the coilpack causing a miss-fire I dumped an entire can of seafoam gas treatment in the tank. Since then the fuel gauge has been working perfect.
Much cheaper than any of the other fixes, worked for me YMMV
You don't need to replace the entire cluster. You only have to change the motherboard for the cluster with a new revised one ($50 with 0 miles on the ODO, $135 for your mileage). 99-00 only have bad fuel sender units, which Toyota released a new sender for ($55-60). Wherever you got $1,000 is ridiculous. See here:
COB's 4Runner Timeline (Pic Heavy)
OP, as far as your 96, I wouldn't put it past the fuel sender unit, but your year isn't listed on the Toyota TSB for bad sender units.
Changing the gauge cluster color is a matter of changing the bulbs with colored LED's, the clock is what requires a transparent film to change the color.
