Old 08-22-2012, 05:37 PM #1
Hunter P Hunter P is offline
Hunter P is on a distinguished road
Fuel gauge needle trouble
So i have a '96 SR5. The fuel gauge needle is always moving up and down within the range of where it is supposed to be, but sometimes it will just drop down to empty and stay there indefinitely. I have ended up just relying on the odometer to tell me when i need to refuel. Is there any way i can fix it?
Also, has anyone seen a write up on how to do the gauge cluster color change using transparent wrapping paper type material? if someone could find that i would really appreciate it.
Hunter P is offline   Reply With QuoteReply With Quote
Old 08-23-2012, 01:25 PM #2
JimG JimG is offline
JimG is on a distinguished road
I had the same problem with my '99 when I got it, at the time I looked up how to fix it and it was around $1000 or more just for the parts (the entire dash cluster needs to be replaced) so I figured using the odometer to keep track wasn't that bad after all.
Due to a totaly unrelated problem with sparkplug blowing out and damaging the coilpack causing a miss-fire I dumped an entire can of seafoam gas treatment in the tank. Since then the fuel gauge has been working perfect.
Much cheaper than any of the other fixes, worked for me YMMV
JimG is offline   Reply With QuoteReply With Quote
Old 08-23-2012, 01:36 PM #3
theizzardking's Avatar
theizzardking theizzardking is offline
theizzardking will become famous soon enough
scan guage II at that point
'76 FJ40, '87 4runner, '98 LC 100, 99 4runner,'02 Tundra,'02 LX470,'08 Tacoma Dbl cab,'09 LC200, '16 Trail Premium. also 76 super beattle,'06 XR650L,'18 Triumph Scrambler-XE.
theizzardking is offline   Reply With QuoteReply With Quote
Old 08-23-2012, 01:36 PM #4
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light
Moderator
Real Name: James
You don't need to replace the entire cluster. You only have to change the motherboard for the cluster with a new revised one ($50 with 0 miles on the ODO, $135 for your mileage). 99-00 only have bad fuel sender units, which Toyota released a new sender for ($55-60). Wherever you got $1,000 is ridiculous. See here: COB's 4Runner Timeline (Pic Heavy)
OP, as far as your 96, I wouldn't put it past the fuel sender unit, but your year isn't listed on the Toyota TSB for bad sender units.
Changing the gauge cluster color is a matter of changing the bulbs with colored LED's, the clock is what requires a transparent film to change the color.
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
Old 08-23-2012, 01:50 PM #5
Thanks for the tip COB, I thought a grand was ridiculous too and didn't pursue it any further at the time, and then after it seemed to fix it's self after dumping a can of seafoam through... I would still suggest they try that first...
Old 08-23-2012, 01:51 PM #6
JasetheDamager's Avatar
JasetheDamager JasetheDamager is offline
JasetheDamager is on a distinguished road
Actually this is one of the last nagging problems on my truck as well. I thought it might be the fuel sender relay, but then I remember reading through COBs' thread and him mentioning the motherboard with correct mileage for 135$
My needle never moves, and never has since I bought my rig 4 months ago. It always stays 3/4 full. Is there a way to tell what the problem is without draining the gas tank and removing it?
I do have an Ultra-Gauge, but I'd still like to have a working gas gauge, just cuz it bothers me, you know? I also need to install a sunroof motor. Sure, I'll probably hardly ever use it, but I'm still gonna fix it.
97 SR5 4x4 (136,000 k) SS Lifted, 33s, Designing my own armor, Slowest jet fighter in the world (Yes I like toggle switches)
JasetheDamager's Build/Upgrade/Noob/Obvious Questions Thread: http://www.toyota-4runner.org/3rd-ge...7-sr5-4x4.html0
JasetheDamager is offline   Reply With QuoteReply With Quote
Old 08-23-2012, 01:58 PM #7
Moderator
Real Name: James
Moderator
Real Name: James
If that works, then awesome. I've put countless cans of seafoam through the fuel system and intake system, didn't help the fuel gauge for me. Guess you're one of the lucky ones!
Old 08-23-2012, 02:05 PM #8
Yes, that's how I feel about it too. I also don't compleatly trust the fix to last so I keep an eye on the trip meter anyway. But that's not an inconvenience since I keep track of the mpg anyway.
Old 08-23-2012, 08:33 PM #9
kball's Avatar
kball kball is offline
kball is on a distinguished road
kball's Avatar
I will add to JimG's comments, my gauge has been acting wonky for a few months now. It's fine until it gets down to half tank and then it would drop to empty and slowly come back up. For the first time a while back I put Marvel Mystery Oil in my tank for two tank fulls. It's been 3 tanks since those 2 and my gauge has been acting fine since.
Hopefully MMO is really that mysterious!! Probably just coincidence though...
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
kball is offline   Reply With QuoteReply With Quote
fuel , gauge , needle , problem
Gauge Needle Removal? Antman 5th gen T4Rs 8 01-31-2012 10:05 AM
1996 4runner RPM gauge needle going crazy tvbuster1 3rd gen T4Rs 2 01-05-2011 01:00 PM
trouble finding white reverse gauge ron70062 3rd gen T4Rs 1 03-02-2008 12:45 AM
New Fuel Gauge Satman Off Topic 0 08-22-2005 06:36 AM
fuel guage trouble suprthug8d 4th Gen T4Rs 1 12-21-2004 02:28 AM
