Old 08-26-2012, 10:29 PM #1
ryankmasuda's Avatar
ryankmasuda ryankmasuda is offline
ryankmasuda is on a distinguished road
Taco steering knuckle vs. 4Runner steering knuckle
I'm getting ready to convert my auto hubs to manual locking hubs.
The Taco knuckle I have doesn't have the ABS sensor and from what I've been told I'll be giving up ABS for the manual hubs. However Singtoe's thread on manual hub conversion shows a knuckle with an ABS sensor. Can I use the 4runner knuckle with all the Taco insides(seals,spacers,bearings,snap rings , etc) and taco axel hub?
The Taco knuckle casting has the same design as the knuckle with ABS so I don't see why it wouldn't work.
Uploaded from the Photobucket iPhone App
1999 T4R SR5 4WD [Nitro 4.88 Gears][Aussie Lockers Front & Rear][ARB Snorkel][231mm Tundra Brakes][Light Racing Adjustable UCA][Tacoma Manual Locking Hubs][Bilstein 5100/Toytec 650lb Coils][Tokiko FJ80 Shocks/OME 2861 Coils][JDM Field Monitor][AOR Hybrid Rear Bumper][HNC Hybrid Front Bumper][Treadwright 315/70R17 Guard Dog]
My Build Thread
ryankmasuda is offline   Reply With QuoteReply With Quote
Old 08-26-2012, 10:55 PM #2
Dous's Avatar
Dous Dous is offline
Real Name: Casey
Dous is on a distinguished road
Dous's Avatar
Real Name: Casey
Yes, but it is a major PITA
Easier just to get rid of the crappy ABS
'98 4runner | SAS'd | Locked F/R | Armored | Supercharged | URD Goodies |
My Build Thread
Dous is offline   Reply With QuoteReply With Quote
Old 08-26-2012, 11:15 PM #3
I'm thinking that either way it will be a PITA. I don't know how many miles were on the Taco they came from so I was going to do new bearings and oil seals. Which pressing everything from the knuckles is inevitable.
My Build Thread
Old 08-26-2012, 11:26 PM #4
curtperry's Avatar
curtperry curtperry is offline
curtperry is on a distinguished road
curtperry's Avatar
The consensus on this board seems to be that we are better off without our ABS. Also, if you take the spindles apart you should replace the wheel bearings while you are in there... more $$$.
'99 Limited, Millennium Silver, E-Locker
Front: '99 Tall Springs, Tundra Bilstein 5100's @ 5th perch, 3/8 in. Top plate spacer, Light Racing/SPC UCA's, 1.25in wheel spacers, sway end links from 2nd gen rear
Rear: Toytec Superflex, 05'+ Tacoma Bilstein 5100's, extended bump stops, extended brake line, e-brake strain relief bracket, 1.25in wheel spacers, front sway bar links, ES sway bushings
Other stuff: 1/2" body lift, B&M tranny cooler, extended rear diff breather, deckplate, blue-wire mod, ARB Tacoma BullBar, Smittybuilt XRC8 winch, 285/75/16's
curtperry is offline   Reply With QuoteReply With Quote
Old 08-27-2012, 12:07 AM #5
MDST's Avatar
MDST MDST is offline
MDST is on a distinguished road
MDST's Avatar
Ryan, you can use the 4runner knuckle with all the Taco insides, but is a real PITA doing it yourself. Some one else = $$$. Ditching the ABS is the easiest way. If not, you must do what singtoe did.
I'm gonna take the easiest way in my manual hub conversion.
I'll be watching this thread!!
Cheers
1994 Toyota 4runner
MDST is offline   Reply With QuoteReply With Quote
Old 08-27-2012, 02:10 AM #6
Cheers
I'll never pay someone else to do something that I can do. It may take some more time and a few four letter words but the satisfaction in the end of doing it myself and learning the breakdown of the assembly is fun and good to know.
Part of the reason I want to keep the 4runner knuckle is that I have the Light Racing ball joint insert that fits in the knuckle installed and the dumb UBJ puller that you can rent is garbage. I'd rather just go buy a 12 ton shop press.
I'll give it a couple days to devise a plan of attack.
My Build Thread
Old 08-27-2012, 09:05 AM #7
Singtoe's Avatar
Singtoe Singtoe is offline
Singtoe will become famous soon enough
Singtoe's Avatar
The knuckle is the same between the taco and the runner.
Some Taco's even had ABS along with the manual hub so they are out there.
I wanted to keep the abs because my wife drives my 4runner once in awhile and if she runs into inclement weather, I would want her to have that option.
I have a 20t press but it was difficult to use because the 4runner hub is so big. I used a Craftsman gear puller and pushed the hub out of the spindle on the work bench. Worked great.
Side note.
Replace all of your seals include the orings in the manual hub.
I had to replace a cv axle this weekend and my hub did not have a drop of water in it. (last month, i took it though a pond and the hub was submerged)
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
Singtoe is offline   Reply With QuoteReply With Quote
White Knuckle sliders DannyLlama 4th Gen T4Rs 88 11-22-2020 07:11 PM
Steering Knuckle Replacement.. jstutz101 4th Gen T4Rs 13 03-28-2017 09:50 PM
Steering Knuckle seal BCfish 4th Gen T4Rs 1 06-16-2012 12:53 PM
Question about spindle knuckle help... jeeper1 3rd gen T4Rs 5 12-12-2011 11:48 PM
Toyota Pickup/4runner Full Knuckle rebuild KIT. NEW!! w/ wheel bearings. 4x4climber For Sale: Suspension/Wheels/Tires 0 09-01-2011 12:18 PM
