Not sure but I don't think there is any difference between the two (ie your on your own with my hints
)). I had mine out last week to trace a short (I have 4WD) but it should be similar. There are three parts held in by clips so I needed to pull. I pulled the cup assembly and then the lower fascia plate. I then pulled of the bezel surrounding the AC controls and vents. All came off without tools. You can then (carefully and labeling) remove the wires to the controls and the radio is right there. I did my radio a while back but I had a brackets kit to mount it and a wiring harness connector to plug into the factory. Be aware that the factory radio is odd sized so you probably need a kit and a plastic pocket unless your replacement takes up all the space. When you replace the three pieces work from the top down since the middle piece needs the cup holder bracket outside it
