Kalva’s 2000 4Runner SR5 Build Thread
My Toyota History:
1977 Celica GT (lost to the Nor’easter of 92’)
1992 Corolla (Gave to friend with 245,000)
2002 Mr2 Spyder (Magazine quality, sold do to having children)
2008 Camry (Lease)
2011 Camry (Lease)
2000 4Runner (Future Daily Driver / Tow Vehicle)
Past Builds:
1984 Monte Carlo SS (sold in H.S.)
1982 Jeep CJ 7 (Engine blew up driving to Campus)
1977 International Scout (Body split in two do to removing the top which then caused the fuel tank to leak out)
2002 Mr2 Spyder (Supercharged w/meth injection, 911 Autocross slayer)
1971 Porsche 914-4 (restored to factory original)
The Condition of my 2000 4Runner SR5 when I picked her up in July of 2012:
129,000 miles
Cracked windshield
Non-working instrument cluster (Tach, Speedo, Fuel gauges)
4 Bald tires
Poor brakes / Squishy brake peddle
Ok/Fair looking interior: Carpets stained, Drivers seat tear, rear seat stained
Stolen Cat & O2 sensors (W/Check engine light)
Sagging rear springs
Needs shocks all around
Sway bar & end link bushings shot
Needs complete tune up
Leaking valve cover gaskets
Dented rear bumper
My goal is to have this 4Runner drive and run as close to stock as possible, maybe a little better. I will not lift it as it will be a DD, yet future plans include but not limited to HD front steel bumper, swing out tire carrier rear bumper, Jerry Can on lift gate, suspension / bushings and a Tundra front brake upgrades. Firstly I will try to replace or repair the above issues then work on fun mods.
1. Once I got the 4Runner home I gave her a full interior cleaning. My wife was amazed at the difference when I was done.
2. The following week I replaced the front brake pads (easiest pads I have ever changed). Then the rear brake shoes and I found the reason for the soft brake peddle feel. The rear wheel brake cylinder was leaking only $17.00 at Advanced Auto and the brakes where firm once again.
3. I found a set of used Sonoran steel shackle hangers, I sand blasted and powder coated them and the shackle screw pin Gloss Black.
4. The Engine bay was bother me as some brackets are starting to rust or oxidize so to the blasting box parts are starting to go. I started replacing some rusting bolts with shining new ones.
5. TBD
The Day I brought her home
Replaced the front brake pads (easiest pads I have ever changed). Then the rear brake shoes and I found the reason for the soft brake peddle feel. The rear wheel brake cylinder was leaking only $17.00 at Advanced Auto and the brakes where firm once again.
Look what came in the mail some used Sonoran steel shackle hangers
A little rough, nothing sand blasting can't take care of
In the box they go
All cleaned up
Eastwood is a great place
powdered
Done baking in my toaster
Time to remove the old hooks
Funny surface rust, never happends on Long Island. A wire wheel with primer and black paint, fixed it right up
All done, before and after
More to come
