Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 02-08-2017, 08:19 PM #31
frodiesel's Avatar
frodiesel frodiesel is offline
frodiesel is on a distinguished road
frodiesel's Avatar
Originally Posted by 1985taylor1925 View Post
I have my throttle body apart right now as I'm trying to figure out my idle issues and noticed that the butterfly doesn't close all the way. There's a slight gap in it top and bottom. But on mine it's because the adjustment screw is set to where it keeps the butterfly just slightly open. I can tell it's been this way for a long time because I can see the yellow loctight hasn't separated.
I am having terrible issues with idle now two weeks after pulling everything off and changing the valve cover gaskets. I have poor idle initially, like to the point of where the truck struggles to start. And then once it's warmed up it idles at 1600+ rpms.
So my questions, is the butterfly supposed to be slightly open at idle? Or should I adjust the screw so it's closed. And does anyone have another idea as to why my idle is so low initially and then high once warmed up?
Throttle body is clean
Gaskets are good
All hoses were attached
One other thing I should add is that I changed the pcv valve, and the grommet was a bit loose. I didn't have a grommet so I just used rtv to seal the grommet to the valve cover, and to seal the pcv to the grommet.
Sounds like you have a vacuum leak so you just manually turned down the throttle. The yellow paint was put there at the factory.
You should replace that grommet asap and never use any rtv where there is vacuum. It will not seal and cause high idle issues, or worse be sucked into a sensor and plug something.
frodiesel is offline   Reply With QuoteReply With Quote
Old 02-08-2017, 09:08 PM #32
1985taylor1925's Avatar
1985taylor1925 1985taylor1925 is offline
Real Name: Phil
1985taylor1925 is on a distinguished road
Real Name: Phil
I checked all the vacuum hoses and sprayed them to see if there were any leaks. Didn't see any. I sealed the outside of the grommet, so not worried about rtv getting in it. But isn't pcv supposed to be air tight? Only reason I sealed it is because I could move the grommet by hand so seems like it wouldn't be sealing
98 - SR5 - 3.4L - 4x4 - Auto - 4:10 gears
http://www.toyota-4runner.org/3rd-ge...my-runner.html
267/75/17 Cooper ATs - Level 8ZX wheels matte black - EBC rotors/ pads - 99 coils/ Bilstein 5100s - deckplate - Sotashi/custom emblem - Hella micro DE fogs - Kenwood/Alpine/Infinity system - sound deadened interior - color matched bumpers - LED tails - Safari LTD rack - Husky floor liners - clear corners
1985taylor1925 is offline   Reply With QuoteReply With Quote
Old 02-09-2017, 02:40 AM #33
frodiesel's Avatar
frodiesel's Avatar
Its not a part that you should use rtv on. It could just be a bad iac valve
Ive cured a looping low idle on my camry with throttle body cleaner before. Not sure if tue 4runner uses the same part.
Old 04-22-2017, 06:47 PM #34
nobb nobb is offline
nobb is on a distinguished road
What an extremely frustrating problem! After doing a full throttle body + IAC cleaning my idle was at 2000+ rpm and would hang when I pressed the accelerator. The washer mod did not fix the problem, what I ended up having to do was add a stronger return spring. Now it idles at 800 rpm...but the disadvantage is the throttle response does not "hang" and feels "heavy."
I didnt realize how sensitive these throttles were!
My High Idle CURED!!!-img_20170422_163355-jpg
nobb is offline   Reply With QuoteReply With Quote
Old 04-22-2017, 07:19 PM #35
baja1 baja1 is online now
baja1 is on a distinguished road
you know just because you cleaned the IAC doesn't mean its working, mine was clean as a whistle but the coil was bad. check out my post on manually operating the IAC.....it works I tell ya!
baja1 is online now   Reply With QuoteReply With Quote
Old 04-22-2017, 07:23 PM #36
I manually applied +12V to the associated pins to test that the IAC opened and closed normally. The IAC was not the problem.
Old 04-25-2017, 12:42 AM #37
As an update with my spring mod, I've noticed that over the course of the last few days of driving and several on/off cycles, I've been able to gradually loosen the spring tension slowly and the idle has been slowly self adjusting. I am at the point where I've removed this spring completely and the idle has greatly settled down.
It seems our ECU might have some self adjusting idle function where over time it gradually compensates for the throttle body behavior. Would be interested if anyone can comment better on how this works. The FSM makes no reference on calibrating the idle. Pulling the EFI fuse and cutting power to the ECU does not seem to reset the idle and it appears the idle relearning process is very slow and gradual.
Old 04-24-2018, 09:55 AM #38
JasonBass's Avatar
JasonBass JasonBass is offline
JasonBass is on a distinguished road
JasonBass's Avatar
new guy here... I need help
I tried the washer mod and now my truck idles at 3k took the washer off and still at 3k all I did was take the nut off and slide the throttle bracket off... with the throttle bracket off it idles at 800 (normal) but if I slowly slide it back on to the end it idles back up to 3k?? ANY IDEAS!?
JasonBass is offline   Reply With QuoteReply With Quote
Old 07-09-2018, 12:04 PM #39
Swede's Avatar
Swede Swede is offline
Swede is on a distinguished road
Swede's Avatar
Loosen your throttle cable maybe?
'98 4Runner, 35" TTCs, E-Locker, 4.88 Yukon's, 3.4L, 5-speed, 3" Susp Lift, 3" BL, Elbow mod, Deckplate Mod, "D" gasket mod, 22" Magnaflow, 231mm Tundra Brakes, 67" TG Sliders, 8500lbs Portable Winch, Airlift Bags, Magellan GPS...
My Build Thread: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Swede is offline   Reply With QuoteReply With Quote
Old 01-27-2019, 06:07 PM #40
k2damfc k2damfc is offline
k2damfc is on a distinguished road
So on mine itís a bit different. I actually have a cable going to the return. I just went thru and did a TB, IAC and MAF cleaning just now and got a high idle (2k) but if I put it in drive I can get it down to 1k but then it starts sounding like it will die, but so far hasnít died at all. Will try this washer mod, seems to be a simple fix, in hopes it is this easy. When I pull the spring back like the return spring would do the idle gets better but the engine sounds worst. Not sure, but is the return cable adjustable? Besides at the throttle body? Iím kinda maxed out on the adjuster.
k2damfc is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 07:38 AM #41
Bill1988 Bill1988 is offline
Bill1988 is on a distinguished road
High idle after fuel pump change
Just recently changed my fuel filter and pump, unfortunately didnít do it myself, I had to raise the white flag because I didnít feel like laying in the snow In my driveway. When I got it back it idles really high, higher than normal... I will look at linkage issue. I was wondering what was going on...
Bill1988 is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 11:58 AM #42
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light
brillo_76's Avatar
Real Name: Jon
How high is the idle?
1997 4X4 V6 5 Speed Sr5 4 Runner (97 5 speed )
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
brillo_76 is online now   Reply With QuoteReply With Quote
Old 02-21-2020, 04:34 PM #43
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a jewel in the rough TheDurk is a jewel in the rough TheDurk is a jewel in the rough TheDurk is a jewel in the rough
TheDurk's Avatar
Last summer, in the heat, I adjusted the accelerator cable right at the edge of too tight. This winter, I paid the price. Once it got below 30įF, the idle would kick up to ~1100 RPM. Today I slacked off slightly, and it's back to a steady 650.
So it is better to do this job in the winter or leave a little slack if the weather is hot.
My Backyard Frame Swap
High Idle Idle After Cleaning Throttle Body hungryeddy 3rd gen T4Rs 22 11-18-2015 01:54 AM
High idle, low idle upon start RAB 3rd gen T4Rs 9 02-21-2014 11:50 PM
99 3.4L SC - High Idle, hesitation off idle, poor mpg and surging. davemw 3rd gen T4Rs 12 07-19-2012 06:56 PM
Idle is too high, help Darrin530 3rd gen T4Rs 2 07-28-2011 06:30 PM
high idle rubbman 3rd gen T4Rs 2 03-20-2008 02:30 PM
