09-03-2012, 09:49 PM
Heated Seats?
Hi Guys, I have an '02 4Runner SR5 with leather seats. It looks like all the wiring is there for heat including a plug behind the blank on the dash. Can I buy an OEM switch and hook it up?
09-03-2012, 09:53 PM
Assuming the heating elements are in the seats, you probably could just add the switches (you might need to also add fuses into the fuse box for the circuits).
Does the wiring under the seats actually connect to the seats?
Eric
'02 Limited
1st Gen TRD SC - 2.2" Pulley - URD 7th Injector - TRD Headers - URD 02 Sim - Hilux Surf Field Monitor Unit - Hilux Surf Power-Folding Mirrors - Hilux Surf Rear Spoiler - Tundra Brakes - TRD Tranny Cooler - OME906 - '99 Front Coils
09-03-2012, 10:00 PM
heated seats
They are, both seats and the plug wires look the same.
09-03-2012, 10:39 PM
I doubt that you have the heater elements in your seats.
I would break the seats down first to see if there are elements there. If they're there - you lucked out and just need a switch, if not, you'll need everything associated - switch, relay pack, elements, maybe even a wire sub harness.
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
09-03-2012, 10:41 PM
My 2001 Limited has two separate switches for the heated seats.
[IMG] ~original[/IMG]
09-04-2012, 12:32 AM
I just checked the FSM and it looks like if you check for wires in pins 2 and 4 on the drivers side and 2 and 3 on the passenger side of the main connector from the harness to the seats, you should be able to confirm the circuit exists (in both the seat and the main harness), and if they have continuity within the seat, I would also assume the heating elements are there.
FYI the switches are expensive (~$100 each), I replaced one of mine as the clip to hold it in the dash was broken.
Eric
'02 Limited
09-04-2012, 01:46 PM
seats
Thanks everyone as always good info!
09-04-2012, 03:28 PM
I have small switches just under my ashtray on the center console. I have an SR5 with leather, heated seats and the sunroof added as options. I'm sure the switches can be rigged without the fancy OEM option.
2001 SR5 4X4, V6, 3.4L
12-12-2013, 01:08 PM
Real Name: Randy
Real Name: Randy
Have to resurrect this thread for a question for those of you that can help: are the '01/'02 OEM heated seat switches only On/Off, or are they Hi/Lo/Off switches? I am installing Innovative Heat II (Hi/Lo/Off) units in my '99 LTD and want to install OEM switches. If the OEM switches are On/Off I'll have to figure out how to make the two get along. Thanks in advance for any help. Didn't want to start a new thread just for this.
'99 Limited 3.4L 4x elocker | TRD Pro gray 17x7 6-Spoke/Falken Wildpeak AT3W 265/70-17SL | BORA .75 Spacers | 4Crawler 2" BL | 5100's x4/OME 906-R/'99 Tall-F| All-Pro Sliders | SRQ Fab. Skid | Chev K1500 Transcooler | Spyder Tails | Clear Corners
Up next: TBU (been saying this for awhile!)
Purch. 08.13-115k; 02.21-168k
12-12-2013, 03:12 PM
My '02 is on/off
2002 4Runner Limited 2WD
1955 Ford Victoria 2dr Hardtop
12-12-2013, 08:30 PM
Look around the pick-n-pulls for a pair of Lexus LS400 seat heater switches. I got mine for like $4/each. They are high/off/low 3-way switches. When I recovered my seats I installed some carbon elements. It has been in the teens the last few mornings and I really need to get them wired up. I don't have any factory wiring so I am just wiring them up like any other accessory.
I think you can find them in black and brown. Don't mind the brake line fittings.
1998 Limited 4Runner, DD and trying to keep it that way.
1988 4Runner, Project in progress
1991 FJ80, the Beast, 10lbs of potatoes in a 5lb sack
1990 Pickup, about to get some needed TLC
12-12-2013, 08:38 PM
Real Name: Steve
Real Name: Steve
Infiniti QX4 switches work too. I have them in my truck.
2003 Silver Pine Lexus GX470- Radflo extended travel/FN BFD’s/Total Chaos/33’s.
12-12-2013, 08:47 PM
@ jreask
are those both for the drivers side or is one for each seat. And is that the factory placement? Just curious because it seems odd that the passenger switch would be out of reach of the passenger.
12-12-2013, 08:58 PM
Real Name: Steve
Real Name: Steve
Originally Posted by mrtucker80
@ jreask
Ya, I didn't like that either. I moved my rear window switch down, eliminated the glass breakage sensor, and put mine here.
These are the QX4 switches.
12-12-2013, 09:03 PM
Any late 90's infinity car will have the same switches as the QX4 as well.
'97 3RZ 5 Speed "FrankenRunner" ( Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - ( Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
