New Leak - Help!
bergeron37
Pulled into the driveway today and noticed fluid leaking from the front end. Picture attached, its the pin dead center in the photo. I couldn't circle it on my mac for some reason. Just left of the rust
It's from your AC, it doesn't actually leak from there but that's where the water usually ends up, mine does the same, try getting under the truck with the AC on and the off and you should see the water drops reduce or slow down
Trdoffroad916
