Old 09-19-2012, 07:59 AM #1
gornish_hick's Avatar
gornish_hick gornish_hick is offline
gornish_hick is on a distinguished road
4wd Issue Has Me Stumped!
I really love my 4Runner but sometimes it's like a nagging girlfriend, it gets a problem and drives a fella nuts. Well about a month ago I lost my 4wd. The t-case would shift in to 4hi and 4lo but It wouldn't shift in on the front diff and my 4wd indicator light would not come on. So I dug out the vacuum tester and had great vacuum to the actuator and electrically everything seemed fine, so I figured I keyed it down to a faulty actuator. I went and picked up a new actuator and installed it on the weekend. After I got it in a threw it in 4wd Hi and Low and the indicator light came on fine and I thought, there I fixed it. Not the case, last night I decided to try it out while just out playing around. Indicator light would come on and it would shift into and feel like it was in 4wd but only the rear would spin. So now I'm stumped, any ideas what might be causing this? Any help would be great, thanks!
1999 4Runner V6 SR5 MT, 1" Diff Drop; Front: Fabtech adjustable coilovers Rear: OME 906's with 1 1/2 coil spacers; 285/75/16 DC Fun Country II
1996 4Runner 2.7L Front 2.5" Daystar spacers Rear: OME 906's with 1 1/2 coil spacers sitting on 34/10.5/15 TSLs 301km's
gornish_hick is offline   Reply With QuoteReply With Quote
Old 09-19-2012, 08:53 AM #2
Bishard Bishard is offline
Bishard is on a distinguished road
Try switching the vac lines connected to the two soleniod switches. The hoses are color coded but I don't remember which one is for 4 and 2wd. Worked for me until getting new solenoid. Good Luck
Bishard is offline   Reply With QuoteReply With Quote
Old 09-19-2012, 08:56 AM #3
Thanks I give that a try!
Old 09-19-2012, 09:22 AM #4
fourwd1's Avatar
fourwd1 fourwd1 is offline
Moderator
fourwd1 has a spectacular aura about fourwd1 has a spectacular aura about
Moderator
fourwd1's Avatar
If the 4wd indicator lights the actuator should be locking the axle for 4wd.
Let's make sure there's not a tcase problem too.
In 2wd grab and rotate the front drvshft, it should rotate freely.
Then put it in 4hi and repeat, it shouldn't rotate freely.
FOUR WHEELER mag July 20xx and OFF-ROAD mag Feb 20xx
'89 4Runner SR5 - stock
fourwd1 is offline   Reply With QuoteReply With Quote
Old 09-19-2012, 08:29 PM #5
Tcase is working like it should , driveshaft is locking in in 4wd, I have a feeling the problem lies in the front, just not sure what other things I should look at.
Old 09-19-2012, 08:59 PM #6
fourwd1's Avatar
Moderator
Moderator
fourwd1's Avatar
I think you need to make sure the ADD actuator is actually sliding over and locking the axle shafts. The 4wd indicator lamp lighting up says it is, but maybe it's hitting the switch for the 4wd indicator lamp before it actually locks the axle.
You may have to disassemble the ADD assy a bit to see.
Old 09-19-2012, 09:19 PM #7
Thats what I am thinking it might be Now after I finally found a diagram of how it works. Thanks for the input, I think im going to take the actuator back off here tomorrow night and have a look in and see what i screwed up on.
Old 09-19-2012, 09:32 PM #8
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
that has a fork, and collar right?
maybe the fork is misaligned, and outside the collar.
nevada is offline   Reply With QuoteReply With Quote
Old 09-19-2012, 09:38 PM #9
That is what i think might be going on with it now
Old 09-19-2012, 09:53 PM #10
cj80cruiser's Avatar
cj80cruiser cj80cruiser is offline
cj80cruiser is on a distinguished road
That is correct.
To OP.....I have one sitting in my shop dissassembled. If something is going on with yours I should have whatever you need.
戦争イーグル
Cory J
Wheel converter,
cj80cruiser is offline   Reply With QuoteReply With Quote
Old 09-19-2012, 10:43 PM #11
revenantdead's Avatar
revenantdead revenantdead is offline
revenantdead is on a distinguished road
before you tear anything out of the driveline, check the ADD relay. it's up in the front uner the dash, behind the passenger side kick panel. the contacts in mine were all types of rusty and corroded.
Betty:97 SR5 succumbed to frame rot
Eileen:98 SR5 in progress...
Facebook:
NJ 4runner Association
Northeast 4runner Owners Association
revenantdead is offline   Reply With QuoteReply With Quote
Another MPG... IM STUMPED MichaelFuller 3rd gen T4Rs 24 03-30-2012 11:52 AM
So stumped with tires... knightsfs4 4th Gen T4Rs 16 11-01-2011 11:31 PM
Electrical issue has me stumped fitzi6_7 Classic T4Rs 10 02-10-2011 08:56 AM
Stumped Toyota Service Department with this issue- can you help? krs1040 3rd gen T4Rs 17 12-16-2008 11:02 PM
please help, i stumped the mechanics with this one farmdog 3rd gen T4Rs 29 05-02-2008 01:30 AM
