Originally Posted by Skulking
Are you sure it is actually coolant that is leaking? Passenger side firewall is where the AC drain line comes out and it just drips to the ground from there.
Now I'm embarrassed, I think maybe it is condensation. I just put a paper towel under the leak and let it run for a few minutes. No greenish color on the paper towel at all. I left this out of my first post for brevity but I took it to get inspected this morning after finishing my gasket job, but it didn't pass for unrelated reasons (steering rack bushings, lower ball joint, front brake lines - I have more fun ahead) but the mechanic mentioned I had a pretty bad coolant leak, which was news to me. I assumed he knew better than I would, so I believed him.
Can I test the heater core by idling the car and running the heat? This would not create condensation but would cause the core to leak if it had one, yes?
