09-26-2012, 09:56 PM
Track Bar and Rear Body Mounts???
My 1996 4Runner suffers from rear sag, and my mechanic says that my rear body mounts are shot, and recommends i find some online for cheaper for than what he can get them for. However, I cannot find ANYWHERE rear body mounts. Also, I need a new track bar, and have been unable to locate one after checking every major parts warehouse online.
Any suggestions?
Thanks
1996 T4R SR5 4WD RED, Goodyear A/Ts, Moog springs - SOLD
1989 T4R SR5 4WD 4 Cyl. 5 Speed Soft Top - SOLD
2003 T4R SR5 4WD V8: Toytec Ultimate Lift w/ Bilstein 5100s, Curt Roof Rack, HCF delete, MB 16x8.5 Rims, 285/75r16 ATs
09-26-2012, 10:33 PM
Maybe just do a body lift now instead of buying stock ones?
And are you wanting a factory trac bar or after market?
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
09-26-2012, 10:49 PM
what's wrong with trac/panhard bar? Don't know how it can go bad other than needing new bushings or being bent. I am sure the dealerships have all these parts. For body mounts, are you talking about the rubber bushings? Other than oem there are plenty of 1" body lift kits to buy.
97 V6 4X4 AT; ICON 2.5 EXT TRAVEL COILOVERS / SS 1.2 REAR; AUSSIE LOCKER; TC UCAs; SAVAGE OFFROAD SLIDERS AND SKID PLATES; ARB BUMPER; WARN WINCH; LOTUS CONTROL ARM SKIDS; DECKPLATE/ISR; 265/75/16 BFG KM2
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
09-26-2012, 11:19 PM
1999 T4R SR5 4WD [Nitro 4.88 Gears][Aussie Lockers Front & Rear][ARB Snorkel][231mm Tundra Brakes][Light Racing Adjustable UCA][Tacoma Manual Locking Hubs][Bilstein 5100/Toytec 650lb Coils][Tokiko FJ80 Shocks/OME 2861 Coils][JDM Field Monitor][AOR Hybrid Rear Bumper][HNC Hybrid Front Bumper][Treadwright 315/70R17 Guard Dog]
My Build Thread
09-26-2012, 11:38 PM
I have a factory panhard bar, PM me if you want it.
1997 3.4l SR5 5spd 4WD E-locked. Blue wire mod, 99 tall springs, 32" Duratracs, Satoshi Grill, Tundra 231 brakes, 99 center console.
1988 3.0l 5spd Pickup SAS on 35s with 5.29's, welded 8.4 rear, custom flat bed, on board air, XRC8 winch, homemade sliders.
09-27-2012, 01:00 AM
Moderator
Real Name: Dylan
Moderator
Real Name: Dylan
Find a new mechanic...
I really doubt your body mounts are causing rear sag. Check the sticky thread at the top of this 3rd gen section for more info about rear sag.
The Rock Turtle Lifted, Locked, Boosted, Armored, TacoBoxed, and awaiting destruction.
09-27-2012, 11:04 AM
Rear sag is common and usually caused by old worn rear springs. Does your 4runner rattle and make noise or just sag?
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
09-27-2012, 09:34 PM
Yes apparently my track bar is bent, and I had all shocks struts and springs replaced recently. My mechanic says that all 4 spring assy's have 11" of height, but the car leans 1.5" to the right. He says that my rear bushings in particular are totally ruined from rot, and my bar is bent and rusted. And btw it just sags no rattle or anything.
Any so if I got a lift kit, the parts would be those rear body mounts?
And if so where can I find these components online?
Thanks a ton
09-28-2012, 12:34 AM
Real Name: Jordan
Real Name: Jordan
We need pics ...
10-23-2012, 08:10 PM
any update?
01-05-2013, 12:39 AM
Sorry about the delay. I ended up replacing the track bar with a factory one - it was bent. The body mounts were rotted out, but I left them as they are. I replaced the shocks with new ones, and it alleviated most of the sag. However, some remains. It isn't as noticeable, but I have noticed that the sag seems fixed when the 4Runner goes up on a lift in the shop. It seems level, but after some time or offroading in a light sense the sag returns. It does not pertain to me as much as I have bought a 2003 4Runner and the '96 is up for sale. I do thank you for your help!
01-05-2013, 12:57 AM
:bangsheadagainstbrickwall: of course it doesn't sag on a lift, the suspension is all stretched out then.
Your rear springs are shot, very common. Replace them. As for the "rot" what exactly do you mean. Unless your truck has a ton of rust, I doubt the body mounts rotted. Most likely the bushings are shot, probably the studs are rusted too. No biggie.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
