09-30-2012, 10:12 PM
What Octane Fuel?
Wondering what octane fuel everyone runs whether or not your supercharged?
1998 4Runner SR5
Mods: lift, tires, cb radio, blacked out things.
Future mods: Center Console Swap, Exterior lighting, Roof Rack, ARB-AIR Lockers
09-30-2012, 10:14 PM
85 works for me
1984 Toy Longbed 4x4: lifted, locked, incapable of highway speed
1985 FJ60: OME, 33's, Lockright, Rust
1997 4Runner SR5: Rolled , 1999 4runner SR5: V6, 5-speed, e-locker, 285's, SS 1.2
1988 FJ62: TBI 350, 700r4, FF rear, ARB locked F/R, almost no rust!
1996 Lexus LX450: Factory locked front & rear, OME lift, and a salvage title
09-30-2012, 10:43 PM
I run 93 in everything for the lawn mower to the 4runner everything seam to run better and the run will get about 60 miles non corrected fuel mileage
09-30-2012, 11:03 PM
I've run 85, 87 and 91 in my 4runner. I have never noticed any power or mpg differences. It doesn't ping on 85 so that is what I run 99% of the time.
2000 4runner Sport, SAS/4wheel Underground 3 link, Diamond axle, 14" Radflo coilovers, double locked, Custom rear 3 link, 12" Fox shocks, full armor Gerdo's Build Thread
Real Fuel Tank Skidplates for sale Lil' Skip's OffRoad
Rear control arm mount skids and Hi-Lift adapter for sale Lotus Development
09-30-2012, 11:31 PM
Real Name: Casey
Real Name: Casey
93 in mine, I would run 87 if I could
'98 4runner | SAS'd | Locked F/R | Armored | Supercharged | URD Goodies |
My Build Thread
09-30-2012, 11:33 PM
87 octane lowest you can get in CA. 02 T4R naturally aspirated
09-30-2012, 11:49 PM
I run 87. They offer 89 with the ethanol out here for cheaper but I don't trust ethanol. Not enough regulation on what percentage of ethanol your getting from the pump. That and ethanol, if left to sit will attract water.
2002 4runner SR5:
285/75/r16 Goodyear DuraTracs, 16" ProComp Rims, 3" OME heavy duty lift, 1" Toytec body lift, 1" Toytec Diff Drop, addicted offroad front bumper, wab fab quick disconnects - front, 7" procomp lights, lil skip's fuel tank skid plate, traction control mod, DRL Mod, Smittybilt XRC8 winch, Optima yellowtop battery, CAI
Last Off-Road Adventure - My Storage Shelf Build - Bottle Jack Awareness - Backfire/Stutter Under Acceleration - Custom Wheel Well Cover
10-01-2012, 12:00 AM
The lower octane fuels (e.g., 85) are only valid for higher elevations because the air is thinner so you're technically not getting the same compression as you would at lower elevation, hence no pinging/pre-detonation. That being said, the only advantage you would ever get from a fuel above 87 octane is perhaps a cleaner fuel (by chance) or maybe lower amounts of ethanol mixed in... ethanol actually doesn't have the same efficiency as gasoline.
So, anyway, I'd go 87 if you live in IN...
2014 4Runner Trail Edition Premium - Magnetic Gray
2001 4Runner SR5 Thread...Sold
2010 Bernese Mountain Dog
1998 4Runner Limited: Smooshed on an icy bridge in MT
10-01-2012, 12:25 AM
87 most of the time. I'm told, unless the person on the pump before you bought 93, the first two gallons or so of your 93 purchase are going to be lower octane anyway because the lines are full of the cheaper gas the last guy used anyway. I've run higher octane in my other cars when called for but my 4R does fine on 87.
10-01-2012, 08:19 AM
Real Name: Adam
Real Name: Adam
87...don't really see a need to run anything higher.
10-01-2012, 08:57 AM
My actions exactly. But here is NC, gas comes 87, 89, Some Gas stations offer 91 and some off 93. Not sure how this works.
Have you tried 91 or 89 for that matter?
I have some customers that work at the oil terminals and they told me a little secrete. All the gas for NC comes from Texas through underground pipe line. They only pipe 3 fuels. Regular, Super and Diesel. Ethanol is railed in from the midwest via tanker cars and is blended at the terminal. Your local gas station mixes super and regular at the pump to offer Mid-grade gas.
In NC - all gas stations sell the same gas. From the same pipe line. The different store brands (Hess, Shell, Exxon, Mobil and etc) have their own additives which they add to the Tanker truck before shipping to the gas station.
I buy my gas from Walmart because it is usually 10 cents cheaper and it does not have all the additives in it.
Side note. With my 4.7 swap, I ran super (91 or 93 depending the pump) for the first 5,000 miles. Then I braved up and tried some regular and my 4runner gets the same milage as before. No knocking or pinging so this is all I run now.
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
10-01-2012, 09:03 AM
This is not true if the pump has separate nozzles for each grade.
When I fill up my Truck, When the pump stops, I insert the nozzle back into the pump to turn it off, i then put the nozzle back into my tank and drain all the gas out of the hose. Once all the gas is drained from the hose, I put the nozzle back into the pump.
I usually get a couple of cups of Gasoline out of it.
10-01-2012, 09:05 AM
Doesn't matter where you are, all gas in the US has at least 10% ethanol in it.
Aviation gas is ethanol free but has lead in it so not good for Cat equipped vehicles.
10-01-2012, 09:14 AM
I used to run 93, but with the price increase over the years, I have scaled back to 89. I have found that the 4runner has run best with Sunoco 89 grade in it. The worst? BP by far.
For long commutes and trips, I still use 93. I seem to get more miles out of a tank than with either 89 or 87.
I don't understand why there is such a great price gap between 87 and the rest of the fuels grades now. It used to be about 10 cents, give or take a few pennies. Not now by far. If anyone has any input for such, I'd love to know.
10-01-2012, 10:51 AM
Ive been running 89 lately. I hear pinging at higher RPMs on 87. Start up seems to take a few more cranks in the morning...
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
