10-02-2012, 10:15 AM
Oil Filter Relocation
Anyone know of any good posts for doing an oil filter relocation? I'm sick of making a mess every time I change my oil and have wanted to do this for some time. I'd like to put it somewhere protected but yet vertical so you can easily change it. Even if I have to cut a hole in the skids it would be better than the way it is now. I would also like to possibly use braided lines just for long term durability. Anyone have a parts list for what I'm looking for?
2001 black 4runner sport
Replaced at 180,000 Miles: Tundra 199mm brake upgrade with Advanced Auto Platinum pads and Brembo rotors and stainless steel extended lines. OME 906s with 10mm trim packer and Bilstein 5100 (Ford F150) in the rear, TRD Tundra springs with Tundra Bilstein 5100s up front. New Toyota lower ball joints, Autozone inner and outer Tie rod ends, and all polyurethane on front and rear sway bars
10-02-2012, 10:49 AM
Originally Posted by Singtoe
That was unbelievably awesome.
99 5 speed 4Runner, 265/75/16 Treadwright Guard Dog MT tires, OME 880 & 90004 with Sonoran Steel machined spacer, OME 890 & 60027with Sonoran Steel Diff Drop, Sonoran Steel Adjustable Panhard Bar, 4XInnovations Front Plate Bumper, Aussie Locker rear, 1" 4crawler body lift, Stubbs HD-SKO sliders,
10-02-2012, 12:21 PM
While that was cute Singtoe, I could have done that. I'm looking for where people have done it on the 3rd gen 4runner. Everyone complains about where the filter is but I haven't seen a whole lot of write-ups on re-locations. I'm looking for placement options.
10-02-2012, 12:27 PM
You know I'm sure there is a jiffy lube that will change your oil without issue. The stock location isn't bad, I've done far worse vehicles.
10-02-2012, 01:00 PM
I had a problem with changing the filter too. I had to crawl under the truck to get to it. That bites. So I relocated the motor to an impala .
Now it is easy to get to.
On serious note. The oil filter is not that had to get to. Some cars have it down deep inside, under exhaust manifolds , behind splash shields and what not.
Mercedes and BMW have their oil filters accessible from the hood area. they can drain and change the oil with out even lifting the car.
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
10-02-2012, 01:33 PM
I miss that pic; if that does not scream NC rural ingenuity right there I don't know what does. I will have to say I did see someone with a 350 engine in a steel wheelbarrow once off 17. No pic though.
I also forgot about the orange kiss of death on there as well.
If one has issues with the oil filter location, try changing one out on an Acura Vigor. One's hands will look like they have been in a bare knuckle boxing match when finished.
10-02-2012, 01:51 PM
Ive never even thought of moving it, but its a good idea in the long run for those of us that actually change our own oil.... But there's one thing that I may see as a problem; since it would be going from the very bottom of the engine (see Singtoe's pic) to a higher position would there be a noticeable drop in Oil pressure? Extending the distance with a hose could also drop the pressure since the oil pump is designed for working without that extra line/height difference. Kind of like using a garden hose... if you have a short hose the water pressure is great but when you use a longer hose the water pressure will drop considerably.
Secondly, when the engine is off could the send/return lines drain back into the engine, causing a delay for the sending of oil into your engine. Since the pump would have to send the oil back up the empty send line, thought the filter, and back down the empty return line.
Don't want to sound like a downer, just my initial thoughts.
10-02-2012, 02:12 PM
If you decide to do it I have a new set of Permacool adapters, one for the engine side and another 90 degree mount for the filter I will sell cheap. No hoses but you can pick them up.
10-02-2012, 02:15 PM
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
Geez Singtoe, you're such a prick..
Here, this ought to get you started. 4Runner Oil Filter Reloaction
lol
here you go dude.. http://www.4runners.org/writeups/permacool/index.html
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
10-02-2012, 11:54 PM
It's not really the location of the filter as much as the fact that its upside down so when you unscrew it, you get oil everywhere. Some places including walmart actually charge extra on this vehicle because they need to remove the skid plate. It's next to impossible to fill the filter before you put it on so it doesn't run dry when you start it.
As for the extra work on the pump, as long as you don't raise the filter more than a couple of inches it shouldn't be a problem. The anti-drainback valve in the filter should stop the oil from draining out of the lines when off.
10-03-2012, 12:44 AM
Wow
This site has really gone bad.
[SIZE="1"]2001 SR5, 140,*** MILES,GLACIER METALLIC, SONORAN STEEL 1.2A, STUBBS HD SKO SLIDERS
TIMING BELT AND WATER PUMP, TOYOTA LBJ S AND OTRs, B&M 70264 TRANNY COOLER, BFG 285/75/16s. SCANGUAGE 2.
I AM "MY MECHANIC"
10-03-2012, 12:58 AM
BMW got it right, very easy to change the filter.
A few on tacoma world have done it. Google 3.4L oil filter relocation kit
Trans Dapt Oil Filter Relocation Install - Tacoma World Forums
10-03-2012, 07:34 AM
The idea of a remote filter mount would seam to worth it if you change your oil often.
But as mention earlier. The pressure drop from adding all the hoses and elbows might cause the oil light to come on while idling.
You add more week points in the system too. Oil hoses coming off, oil hoses rubbing on each other, more vernable oil filter location for damage to occur, more contaminated oil still left in the engine during the oil changes and maybe longer dry starts.
The only benefit I see that is worth anything is to add an oil cooler inline with the remote oil filter. But oil temps seam to always be in check so it is kind of useless to add one.
But each is to there own.
I have to remove my skid plate so my oil filter is a pain in the ass to change but I manage.
10-03-2012, 07:58 AM
Location: Stationed in Camp LeJeune, home is Conover, NC
x1k.
If you don't like getting oil everywhere, put come cardboard or something under the truck when you change the oil. Go get some kind of basin, or make something so you can pull the truck over it, and it'll catch the oil when it comes out of the filter.
There are solutions to everything. Why jump to the hardest thing you can do when you can just lay a big piece of cardboard down?
If youre b!tching about getting the filter off, use a swivel and a couple extensions, and one of those cup wrenches. Take the driver wheel off, and boom, there ya go. You can always go hard over to acess the filter too.
Otherwise, just take it somewhere and get it changed.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
