Old 10-05-2012, 08:35 PM #1
chimpy's Avatar
chimpy chimpy is offline
Real Name: Brian
chimpy is on a distinguished road
chimpy's Avatar
Real Name: Brian
Front wheel bearing?
Getting a low hum coming from what seems to be the front passenger wheel. It seems to quiet down when making a right turn and gets louder when turning left especially at higher speeds. If it is a wheel bearing(my guess), what kind of job is ahead of me. My other vehicle is a 1999 ZR2 Blazer and the hub/bearing is all one part with the wheel studs and anti-lock brake sensor. Pretty simple to change out.
I have tools so no worry there. Just looking for some FYI's/tips before I tear into this.
You can't fistfight tyranny!
chimpy is offline   Reply With QuoteReply With Quote
Old 10-07-2012, 08:25 AM #2
tacojeff's Avatar
tacojeff tacojeff is offline
tacojeff is on a distinguished road
tacojeff's Avatar
Its a pretty straight forward job. You are going to have to pull the front hub off, you can leave the lower ball joint, but you will have to get the front one apart. Once the hub is off the truck its just a matter of removing the seals/snap ring and pressing out the bearing. You will need a substantial shop press. I bought a 20 ton press specifically for this and was hanging on the bottle jack lever to get enough force. Hardest part was getting the hub stable in the press. Unless you already have a press, I would just pull the hub and bring it to a shop to have them swap the bearing.
tacojeff is offline   Reply With QuoteReply With Quote
Old 10-07-2012, 11:32 AM #3
chimpy's Avatar
Real Name: Brian
chimpy's Avatar
Real Name: Brian
Thanks for the heads up. Will be tackling this soon before the Ohio winter sets in!
Old 10-09-2012, 12:35 AM #4
Nelsonmd's Avatar
Nelsonmd Nelsonmd is offline
Nelsonmd is on a distinguished road
Nelsonmd's Avatar
Check out my build thread, I replaced both of mine myself. I used a 12 ton harbor freight press and I didn't have to hang on the arm. I also used a harbor freight 3-jaw puller with some success, though I ended up breaking one in multiple places. Definitely take your time to make sure it's stable in the press. Taking it to a shop is a good idea too, definitely alot easier.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Nelsonmd is offline   Reply With QuoteReply With Quote
Old 10-09-2012, 01:30 AM #5
Royisme Royisme is offline
Royisme is on a distinguished road
I've taken a few to a shop now and so far haven't regretted it. Of course in my case, there are a dozen fairly slow shops within a 10 minute walk for me.
1980 Toyota Pickup SR5, 4x4 w/20r - Kept stock & sold
1984 Toyota Pickup, Extra Cab, 4x4 w/22R - Lifted, wheeled, broke, fixed, wheeled, broke (that repeats a lot for this one...) sold.
1986 Toyota Pickup SR5, Extra Cab, 4x4 w/22R-E - Kept stock & stolen
2000 Toyota 4Runner SR5, 4x4 w/5VZ-FE - Keeping mostly stock... plans TBD.
Royisme is offline   Reply With QuoteReply With Quote
Old 10-09-2012, 10:30 AM #6
Stick Figure's Avatar
Stick Figure Stick Figure is offline
Stick Figure will become famous soon enough
Exactly what I used as well with no issues. worked equally as well for the rear bearing removal.
Stick Figure is offline   Reply With QuoteReply With Quote
Old 10-09-2012, 11:11 AM #7
Nelsonmd's Avatar
Nelsonmd's Avatar
Did you replace you ABS ring and retainer, or did you re-use? I just had a rear bearing go out and fortunately I had my spare set of axles from before my axle swap, but I would like to try replacing those as well. I don't want to buy new retainers and ABS ring though.
Old 03-11-2014, 08:08 AM #8
fishin fishin is offline
fishin is on a distinguished road
Bearings
Where do you take the hub to to have the bearings on a 05 replaced? A repair shop or a machine shop? Do you need to pack the bearings with grease before you take it to them? Thanks.
fishin is offline   Reply With QuoteReply With Quote
Old 03-11-2014, 08:31 AM #9
audiness's Avatar
audiness audiness is offline
audiness will become famous soon enough
audiness's Avatar
most competent automotive shops will have a big press. Don't take it to jiffy lube or one of those abysmal places like that.
audiness is offline   Reply With QuoteReply With Quote
Old 03-11-2014, 08:46 AM #10
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
A repair garage frequently doesn't want to do piecework like that though - they'll say something about liability and try to get you to bring the truck to them so they can charge you for the whole job.
In my experience, machine shops are used to driveway monkeys who just lack that one critical tool and are happy to help out.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 03-11-2014, 09:31 AM #11
Nelsonmd's Avatar
Nelsonmd's Avatar
Is the 05 also a press-fit bearing or is it in a carrier? If they went to a carrier design, then you don't need any special tools.
Old 03-13-2014, 08:31 AM #12
Bearing
Got it done. Took it to a local machine shop to have it pressed off and new one on. Much cheaper. Different set up then I've ever seen but not a bad job. I found it odd that the brake line to the caliper was rigid tubing so make plans to tie up and secure the caliper. Amazon had the best price on the part. Mine was a bearing module or bearing hub, depending where you look. Thanks for your inputs.
Old 10-14-2020, 07:56 AM #13
guiaoster guiaoster is offline
guiaoster is on a distinguished road
Can I just replace the bearing and reuse the hub?
guiaoster is offline   Reply With QuoteReply With Quote
Old 10-14-2020, 12:43 PM #14
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
@infamousRNR and I have two videos that would help anyone accomplish this job. Our Upper Balljoint Replacement video would be a good tutorial to show you how to remove the steering knuckle and get it back on. Our Manual Hub Conversion Part 2 video is a good tutorial to show you how to accomplish the required press work.
Old 10-14-2020, 12:45 PM #15
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Yes, you can reuse the hub. Check out the videos I posted above to help you with this job.
Front Wheel Bearing Replacement gstai 3rd gen T4Rs 8 11-18-2012 04:34 AM
2004 AWD Front wheel bearing bad again! cbdooley 4th Gen T4Rs 1 10-18-2011 03:28 PM
Doing a front wheel bearing myself... do they need to be pressed or not? babyeater304 3rd gen T4Rs 4 08-21-2011 03:54 AM
Front Wheel Bearing for 03+ 4WD Cubslover For Sale: T4R Items 1 08-02-2011 10:18 PM
How to replace front wheel bearing. kevincook Maintenance/Detailing 17 08-24-2009 01:38 PM
