10-08-2012, 03:24 PM
Real Name: Johnny
Real Name: Johnny
OME 891's and bilstein 5125s (that came w SS 1.2 lift)
I am quite fed up w my LC coils in the rear (I tow too often and now have custom rear bumper). I am planning on the OME 891s.
question is, are the bilsteins gonna be ok? too long? Thanks in advance my 4runner homies.
2000 4Runner SR5, 5vz-fe, 5speed, 246k miles, bfg 35's on stock 1985 4runner wheels
10-08-2012, 03:28 PM
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
10-08-2012, 03:50 PM
Real Name: Johnny
Real Name: Johnny
FAIR ENOUGH! Decision made. Thanks man!
Originally Posted by ARKRWLR
10-08-2012, 04:49 PM
why don't you try out the superflex coils? or even 861's
10-08-2012, 05:16 PM
Real Name: Johnny
Real Name: Johnny
What are the 861s rated for. I don't know anything about these superflex coils either
05-14-2013, 07:35 PM
What is your rear height with the ext length? Do you have any pictures of how the truck sits
05-15-2013, 08:50 AM
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
Driver side is like 24" center hub to bottom of flare, passenger is about 24.5". May vary depending on your flares. Keep in mind I also have a lot of weight in the back bc of the rear bumper and cargo boxes. It was always slightly raked before all that. I'd say almost an inch over the measurements above.
05-16-2013, 04:20 PM
Very clean thank you for posting your photo. Do you think the ext length is needed for a rear bumper? or do you think it would sag with regular length shocks? Sorry for another question but what do the flares have to do with it? Thanks for getting back to me
05-16-2013, 04:32 PM
Those 861's like to sit low in the rear. If you like the raked look of your LC coils you want to go with the other coils that where mentioned.
05-16-2013, 05:00 PM
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
It's not so much the sag being caused from shocks as it is the coils. With lesser duty coils my rear end would sag really bad. But because of the medium duty coils it compensates for the weight. The ext length shocks just allow me to maximize the flex I get out of rear suspension. With say some OME comfort shocks or something else the ride might feel better but I wouldn't see as much flex. The shocks would either max out possibly causing damage in the future or I'd have to extend my bumpstops so the axle hits them first. It's better to rely on your bumpstops being the first to stop your rear flex, not your shocks.
Oh and I just mentioned the flares because if say someone had the exact same setup as me and they had sr5 flares or no flares at all the measurements might be off just a tad bc you're changing an end point.
05-17-2013, 01:14 PM
Damn those 80 series landcruiser wheels/tires look good on there.
09-18-2019, 06:54 PM
Originally Posted by JWaldz
Which 5125's did you use? 4wheel parts has a bunch of different ones. I also want to use the OME 891. How is the lift/flexing?
09-19-2019, 12:06 PM
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
I'm not quite sure what part number they were. Toytec use to sell them as extended travel versions with eye to stud adapters. Doesn't appear they sell them anymore, but you can shoot them an email or call to find out I'm sure.
The 891's were ok. They handle weight well until they inevitably start to sag. They're also short in length, so they like to fall out or move around while articulating the suspension.
09-19-2019, 05:44 PM
Real Name: Eric
Real Name: Eric
with a rear bumper and towing, the 891s will sag
I switched to the 861s. I'm ok with a little rake and sits level when towing.
2001 Toyota 4Runner SR5 4x4
3" SS lift
285/75R16 Cooper Discoverer ATP
Outdoor Logic Front Bumper / Savage Off-Road Rear
Visit my garage for the full list
