Old 10-15-2012, 11:49 PM #1
Layne.Saliba Layne.Saliba is offline
Layne.Saliba is on a distinguished road
1999 Toyota 4runner front lift
So I have a 1999 t4r and Im wanting to lift it about 3inches. I bought the LC coils to lift the rear. Now I'm wondering what is the best/cheapest way to get the front lifted. Also once it's lifted what size tires I should run with the stock rims. Thanks.
Layne.Saliba is offline   Reply With QuoteReply With Quote
Old 10-16-2012, 12:02 AM #2
revenantdead's Avatar
revenantdead revenantdead is offline
revenantdead is on a distinguished road
well that all depends. did you want to go cheap? or did you want to go best? TheLift FAQ should give you all the options. search out rickashay's review of the tundra coils vs. OME coils too.
Betty:97 SR5 succumbed to frame rot
Eileen:98 SR5 in progress...
Facebook:
NJ 4runner Association
Northeast 4runner Owners Association
revenantdead is offline   Reply With QuoteReply With Quote
Old 10-16-2012, 12:06 AM #3
TRDteen's Avatar
TRDteen TRDteen is offline
Real Name: Matt
TRDteen is on a distinguished road
TRDteen's Avatar
Real Name: Matt
The cheapest way to lift it would to get coil spacers, they'll run you about $120-$150. I really don't recommend those because of the many complaints I've heard about the ride that they give. But I personally have not tried them. I would recommend any OME front coils and the Bilstein adjustable shocks.
Tread lightly and see you guys on the trail.
'99 Build Thread: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'98 Build Thread: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
TRDteen is offline   Reply With QuoteReply With Quote
Old 10-16-2012, 05:17 AM #4
thebrandon's Avatar
thebrandon thebrandon is offline
thebrandon is on a distinguished road
thebrandon's Avatar
I have adjustable bilstein 5100's up front and absolutely love the ride. Worth the money IMO.
thebrandon is offline   Reply With QuoteReply With Quote
Old 10-16-2012, 07:42 AM #5
I was thinking about getting the bilsteins but then heard about the tundra coils. In your opinion, which would be better? And if I went with the tundra coils, would the lift be even in the front and back?
Old 10-16-2012, 08:30 AM #6
fightman80's Avatar
fightman80 fightman80 is offline
fightman80 will become famous soon enough fightman80 will become famous soon enough
fightman80's Avatar
Smile
I'm running full Tundra Struts from a 2002 TRD Access Cab 4X4. I personally love the ride, and was a cheap setup considering I bought the assemblies used from an Autowrecker. I searched for a low mileage set, and swapped out my top plates onto the tundra setup so it would bolt up to the my front end.
The lift will NOT sit level, as the front will be lower than the back by at least an inch and a half. (depending on what LC coils you have,) That being said, I like the raked look, it looks more aggressive to me, and is nice when towing, as the back doesn't sag lower than the front....
Hope this helps.....
1998 4Runner SR5, ISR and Deckplate Mods, Painted Intake Manifold, TRD Tundra Struts, Diff Drop, LC 8 Wraps w/ Skyjacker shocks, Panhard Drop Bracket, Rear Tire Carrier, Maxxis Bighorns, Procomp Wheels, Custom Front Valance, Sport Edition Skidplate, Upgraded Exterior lighting
fightman80 is offline   Reply With QuoteReply With Quote
Old 10-16-2012, 09:14 PM #7
Do you mind posting a pic of your runner so I can see if I like the look with the tundra coils?
Old 10-16-2012, 11:12 PM #8
ok. Bilsteins would be the struts that the Tundra coils are mounted on. the other common option is Old Man Emu (usually shortened to OME) coils on the same company's Nitrocharger strut.
these would be toyota stock bilstein struts from a newer tacoma or fj cruiser.
you could, if you wanted to, run an OME coil on a bilstein shock and vice versa a tundra trd coil on a OME nitrocharger.
Facebook:
Old 10-17-2012, 12:25 AM #9
TRDteen's Avatar
Real Name: Matt
TRDteen's Avatar
Real Name: Matt
On the toytec website it says "OME 883 and 882 coils only work with the OME nitrocharger shocks" . Is that true or can i run OME 883 with bilstein 5100 shocks?
1999 , 4runner , front , lift , toyota
1999 Toyota 4runner body lift Layne.Saliba 3rd gen T4Rs 11 02-14-2011 09:54 AM
1999 Toyota 4runner lift Layne.Saliba 3rd gen T4Rs 9 02-08-2011 03:21 PM
1999 Toyota 4runner lift Layne.Saliba 3rd gen T4Rs 2 02-05-2011 09:03 AM
1999 Toyota 4runner lift Layne.Saliba 3rd gen T4Rs 8 02-04-2011 07:39 PM
1999 Toyota 4Runner 4x4 Lift? Jordan Petry 3rd gen T4Rs 3 08-05-2008 12:37 PM
