Old 10-22-2012, 11:33 AM #1
Blitanicle99's Avatar
Blitanicle99 Blitanicle99 is offline
Blitanicle99 is on a distinguished road
3.4 Engine Running Rough, Codes, Crappy mpg
Alright, just did a 3.4 swap to 3.4 swap. Its 96-98 engine, I found this out due to the thicker engine mounts.
Engine has 70k on it. Runs really good, but rough at idle. Doesn't like to be floored in neutral, it kind of spits for a second and then revs up.
Pulled the codes, P-0171 (System to lean, bank 1) P-0120 (Throttle position Sensor) and a second P-0170.
*I will add I used the harness that came with the truck, not the harness on the motor I bought and I have 1 two prong connectors at the front left of my timing cover, and 1 one prong connector in the same spot with nothing that I can find goes to. Can't figure out where it went on the other engine either. I'm kind of stumped on that one.*
Anyway, I swapped out the TPS sensor from the other engine, it looks new so I tried it. Cranked right up, seemed to run just about the same with no change.
I am 98 % I've got every vacuum line perfect and no leaks. I'm good on my connectors (except those random 2). It runs 80 down the highway, no stalls, but REALLY doesn't like to be low on gas. Acts like its got crap in the tank.
Its getting like 45 miles per quarter tank currently. It also has a minor exhaust leak, I can barely hear it but no smoke, or smell that I can tell.
Any help with this would be great. I really need this in perfect running shape with decent mpg so I can start taking it to my new job next week and I won't have time to keep screwing with it. Planning on Sea-Foaming it today and changing the plugs this weekend but stumped on the other issues.
*Posting this on TR4.org as well.**
05' SR5 V8 - Revtek 3" - HIDs
00' Limited OME 4"-33s-ARB-PIAAs-Wheel Spacers
03 Tundra... 3 inch lift... Dents
99 TRD Taco, SAWs, ARB, Sliders, Dents
83 Fully built, 37s, 5.29s, Lockers F&R, Exo
Blitanicle99 is offline   Reply With QuoteReply With Quote
Rough running engine [4 cyl ] doug2004toyota Problems & Warranty Issues 2 01-23-2015 10:16 PM
truck running rough after not running at all 4fishrunner Classic T4Rs 5 06-28-2012 03:53 AM
99 - Checking CEL Codes - Low RPM Rough Running Torinate 3rd gen T4Rs 8 03-21-2009 09:26 AM
Rough Idle, Codes 25,26 Paulc Problems & Warranty Issues 0 02-22-2006 08:25 PM
Rough running, misfiring engine under load Leebo Problems & Warranty Issues 0 01-25-2006 10:36 PM
