10-24-2012, 02:36 PM
Double cardan joint make noise when bad??
for the longest time now i've heard a deep groan when the suspension is flexed even a little. pulling up into a driveway or crossing any sort of dip at an angle... it almost sounds like slow speed tire rub (but it isn't), but only metallic. i cant think of anything else near the area i swear i hear it from except the double cardan joint, sometimes i can feel it too. anyone have any insight?
'99 Ltd 4x2
Some welders
10-24-2012, 02:55 PM
Check the tie rods and sway bar bushings.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
10-24-2012, 03:00 PM
I'll check them but I'm 98 % sure its coming from the center and rear of the truck. It may be in my head but it seems to give additional rolling resistance when it happens.
'99 Ltd 4x2
Some welders
10-24-2012, 03:17 PM
Real Name: Casey
Real Name: Casey
Yours is 2 wheel drive correct?
If that is case you have no double cardan, instead, just two replaceable U-Joints.
'98 4runner | SAS'd | Locked F/R | Armored | Supercharged | URD Goodies |
My Build Thread
10-24-2012, 03:19 PM
I have a 4wd Sr5, also sway bar bushings and control arm bushings look good.
'99 Ltd 4x2
Some welders
10-24-2012, 03:23 PM
Real Name: Casey
Real Name: Casey
Oh I see now, I just glanced at your sig really quickly.
Is it lifted at all? When the driveshaft contacts the gas take during articulation you will feel/hear a grinding. It also causes the driveline to bind
My Build Thread
10-24-2012, 03:42 PM
Couldn't resist, my apologies.
10-24-2012, 05:43 PM
Not lifted but I'll double check for contact. It does it when I'm driving on the street too, just going over a mildly ridgy intersection or small speed bumps. I think I'm going to have wedge myself under there and ask my wife to drive around lol.
'99 Ltd 4x2
Some welders
10-24-2012, 06:27 PM
I have the same noise in my truck, although it is seasonal - stock suspension with 194k. Mine likes to annoy me when I am backing out of the driveway - I just heard it for the first time the other day after not hearing it for months. I believe that it is the swaybar bushings.
1999 4runner SR5 212k and still going
Build/Maintenance Thread
10-24-2012, 08:26 PM
Real Name: Vince
Real Name: Vince
I just traced my mystery noise to the double cardan last week. It was driving me crazy that I couldn't figure out where it was coming from. Since I could only hear it when driving, I wrapped my phone in some packing tape, put 4 magnets (use neodymium, and you won't have to worry about it falling off) and wrapped it again in more tape. I set the phone to record and stuck it to the frame rail. Went for a drive and listened to the recording. I had to move the phone to a few different spots before I was finally able to pinpoint the source. It was ridiculous how loud the noise was when the phone was near the cardan joint. I would recommend using a cheap digital recorder rather than an expensive phone, but at the time, I just didn't care, I just wanted to find the source of the noise. Good luck with it.
10-24-2012, 08:57 PM
For me, best way to be sure is to grease all your joints, slip yoke and the carden ball. There should be 5 total zerks to grease. I did this and my sound away. That's how I knew it was my driveshaft. I recently had mine totally rebuilt. The double carden is a major pia to do yourself. And Toyota says to replace with new drive shaft, they won't rebuild it. Good luck.
97 V6 4X4 AT; ICON 2.5 EXT TRAVEL COILOVERS / SS 1.2 REAR; AUSSIE LOCKER; TC UCAs; SAVAGE OFFROAD SLIDERS AND SKID PLATES; ARB BUMPER; WARN WINCH; LOTUS CONTROL ARM SKIDS; DECKPLATE/ISR; 265/75/16 BFG KM2
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
01-03-2017, 07:40 PM
The double cardan joint on my 4Runner was making a ratcheting sounds in 1st and 2nd around 19K-23K rpms. Using a chassis ear I mis-traced the sound to the transfer case which is the closest part to the driveshaft I could clip a mic to. I didn't figure out the DC joint was bad until my whole truck began shaking bad going above 60mph.
01-03-2017, 07:46 PM
I recently had a mystery noise and it went away after I greased just the center joint behind the transfer case. I've heard it's best to just take the job to a gear and axle shop for a rebuild.
-2005 4Runner Limited V8 AWD - Toytec Boss Suspension, SPC UCAs, 285/70/17 Level 8 MK Wheels (17x8, -10), Tandem Rock Sliders
-1998 LX470 (Stock)
www.KeenanOffroadFab.com
