Old 11-02-2012, 08:17 PM #1
Forrrrest's Avatar
Forrrrest Forrrrest is offline
Forrrrest is on a distinguished road
Forrrrest's Avatar
front wheel bearing replacement
Hey all, It's about time to replace passengers front wheel bearing. I've been looking around and can't find any good how too's on this topic. I am aware that it needs to be pressed in/out, I have that covered for the free!! I'm curious as to what all needs to be disconnected also what parts. So far I can think of wheel bearing (duh) 2 snap rings I believe, abs ring, and axle seals, anything else??? If youve done this or know where a good how to is i'd greatly appreciate some of your knowledge. Also It's a 2000 runner
00 4runner 3.4l 5-speed
Front 5100/Eibachs Rear 5125/LC 8wraps
In need of 35s
Forrrrest is offline   Reply With QuoteReply With Quote
Old 11-02-2012, 08:44 PM #2
Stick Figure's Avatar
Stick Figure Stick Figure is offline
Stick Figure will become famous soon enough
Its pretty straightforward:
Remove the brake, abs sensor, and lines
remove the axle nut
remove the upper and lower ball joints (outter tie rod comes with the lower)
Take the knuckle assembly to your freebie press
I wish I would have taken more photos, but the couple I snapped are here
Introduction, and eventualy upgrade thread......
Stick Figure is offline   Reply With QuoteReply With Quote
Old 11-03-2012, 06:38 PM #3
Nelsonmd's Avatar
Nelsonmd Nelsonmd is offline
Nelsonmd is on a distinguished road
Nelsonmd's Avatar
Yeah, it is pretty straightforward. Just be very observant of how everything comes apart as you have to put everything back together in the right order, and you don't want to forget anything. Follow the FSM.
Check out the link in my sig, I took some pictures too, but not too many. If you have never replaced bearings before, use the old bearing races to drive in the new ones. Other than that, not as much too it as people probably think. Again, just be careful about putting everything back together in the right order.
If I were you, I'd try to re-use your seals. The outer seal is like $40 each. Just be sure to grease it before you put it back in, and try no to damage it while removing it.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Nelsonmd is offline   Reply With QuoteReply With Quote
Front wheel bearing? chimpy 3rd gen T4Rs 19 11-05-2020 11:44 AM
Front Wheel Bearing Replacement gstai 3rd gen T4Rs 8 11-18-2012 04:34 AM
Front Wheel Bearing for 03+ 4WD Cubslover For Sale: T4R Items 1 08-02-2011 10:18 PM
4th gen Wheel bearing replacement (part link) ??? Streetfighter Maintenance/Detailing 1 01-31-2011 01:19 AM
Rear Wheel Bearing replacement questions PegramPete 3rd gen T4Rs 2 12-20-2010 10:10 PM
