Old 08-14-2013, 12:58 PM #16
wheelds's Avatar
wheelds wheelds is offline
wheelds is on a distinguished road
wheelds's Avatar
My Gear shifter doesn't rattle but it rocks back and forth, like "sways" with stopping and going. My 4wd shift knob vibrates like a mofo though.
2008 SR5 Titanium Metallic 2x4 - 60k
2001 SR5 Sport 4x4 Black - 135k
wheelds is offline   Reply With QuoteReply With Quote
Old 08-14-2013, 01:14 PM #17
5vzT4R's Avatar
5vzT4R 5vzT4R is offline
Real Name: Josh
5vzT4R is on a distinguished road
5vzT4R's Avatar
Real Name: Josh
My gear shifter does the same, sways back and forth but the whole time while I'm driving. I can feel it with my hand on the shifter like its "floating". But not my 4wd shifter, that one is pretty tight.
2005 v8 Limited 4wd
5vzT4R is offline   Reply With QuoteReply With Quote
Old 08-14-2013, 01:20 PM #18
crazydubman's Avatar
crazydubman crazydubman is offline
crazydubman is on a distinguished road
Same here. I get a lot of movement with the 4x4 shifter. My auto shifter when I drop it in to drive, sometimes will click back up to seat in drive like it goes a hair to far then I tap the shifter and it locks in. Not sure if that is a bushing issue or not but maybe. I probably should look into new bushings and a new trans case mount or perhaps a poly transfer case mount to help keep it solid. hmmm...
Todd:
1997 4runner limited - crawling/camping
http://www.toyota-4runner.org/3rd-ge...ner-build.html
crazydubman is offline   Reply With QuoteReply With Quote
Old 08-14-2013, 02:59 PM #19
NateMob's Avatar
NateMob NateMob is offline
Real Name: Nathan
NateMob is on a distinguished road
NateMob's Avatar
Real Name: Nathan
Mine has started to do the same thing you are describing above. If you look into enhancements for either shifter let me know what you find out.
Sold the 3rd Gen, someone totaled my 4th Gen. Sold the LT'd Tacoma. Finally got my FZJ80!
NateMob is offline   Reply With QuoteReply With Quote
Old 08-14-2013, 03:00 PM #20
Ruiner's Avatar
Ruiner Ruiner is offline
Ruiner is on a distinguished road
Ruiner's Avatar
alittle movement is normal, if its alot, you may need a new tranny/transfercase/front diff mount
Ruiner is offline   Reply With QuoteReply With Quote
Old 08-14-2013, 03:03 PM #21
Ruiner's Avatar
Ruiner's Avatar
you need to adjust this:
if/when you do make sure the car has the Ebrake on and the wheels are chocked so you dont run yourself over if you accidentally pop it into nuetral
Old 09-07-2013, 12:48 PM #22
fblainen11 fblainen11 is offline
fblainen11 is on a distinguished road
Thanks for the help. Just did this and the wife (who drives it daily) loves it. It was one of her biggest complaints. I also adjusted the position of the arm that attaches the shifter to transmission. It got rid of the front to back play in the shifter.
fblainen11 is offline   Reply With QuoteReply With Quote
Old 10-30-2013, 06:41 PM #23
dgoll75's Avatar
dgoll75 dgoll75 is offline
dgoll75 is an unknown quantity at this point
dgoll75's Avatar
Wow what a difference!!!! Just did this too. Thanks for the info fellas!
97 SR5
dgoll75 is offline   Reply With QuoteReply With Quote
Old 12-17-2013, 05:16 AM #24
drohrer drohrer is offline
drohrer is on a distinguished road
My 3rd generation shifter is loose higher or above the bushings like half way up the handle. In the parts diagram from above it would appear to be 33631 and how it is threaded onto the handle. Anyone been in there to assist?
drohrer is offline   Reply With QuoteReply With Quote
Old 12-17-2013, 09:45 AM #25
Pioww Pioww is offline
Pioww is on a distinguished road
This should be stickied it will probably happen to all vehicles with time. And added to a list of common problems.
Pioww is offline   Reply With QuoteReply With Quote
Old 05-06-2014, 10:11 AM #26
brian4t's Avatar
brian4t brian4t is offline
brian4t is on a distinguished road
brian4t's Avatar
I hate to bring this back from the dead but adjust the linkage? How? Unscrew it while in park and sort of reset the position? I'm just not following. My shifter sways up and down over every bump in the road. Wondering if that's normal.
brian4t is offline   Reply With QuoteReply With Quote
Old 05-06-2014, 11:56 AM #27
Ruiner's Avatar
Ruiner's Avatar
yeah, its a bolt than you loosen and move the rod back and forth. but the up and down is most likely:
Old 06-19-2014, 12:29 PM #28
westerplatte21 westerplatte21 is offline
westerplatte21 is on a distinguished road
Quantity?
Here is what you need to fix it. The rubber bushings in mine disintegrated, and on hard acceleration it would vibrate and rattle like crazy. It also felt crappy when shifting in ton gears.
there are two rods one on the top of the shifter plate, one on the bottom. So you will need 4 bushings.
part #33501G
you can order them here
SHIFT LEVER & RETAINER. Fits: TOYOTA | Village Toyota Parts
here is with the new bushings in
Ruiner,
Does a single order from that website contain the 4 necessary bushings or will I have to place 4 orders/quantity?
Thanks
westerplatte21 is offline   Reply With QuoteReply With Quote
Old 06-19-2014, 01:56 PM #29
Ruiner's Avatar
Ruiner's Avatar
Originally Posted by westerplatte21 View Post
Ruiner,
Thanks
you have to order a QTY of 4, i also updated the pic link in the first post
Old 08-24-2015, 03:08 PM #30
Whitedevil13 Whitedevil13 is offline
Whitedevil13 is on a distinguished road
I have a 1992 4runner AT and my floor shifter has the same issue of rattling around. It doesn't allow me to turn the off all the to remove it without jamming around that shift lever to get the key out. Will replacing the 4 shift bushings help that or do I have a linkage problem somewhere else?
Whitedevil13 is offline   Reply With QuoteReply With Quote
WTB: Auto 4wd shifter w/ button JML50 Want to Buy/Trade 0 04-13-2012 09:42 PM
Auto shifter hot! rlpjw1959 Classic T4Rs 5 02-06-2012 11:54 PM
94 4runner 3.0 auto only moves in 4low help! 94runner3.0 Classic T4Rs 0 03-22-2011 10:40 PM
New 1989 T4R - Help with loose Auto Shifter rlpjw1959 Classic T4Rs 3 11-26-2010 05:27 AM
Auto Shifter Bushings available? MattinLA 3rd gen T4Rs 1 08-29-2010 01:31 AM
