Old 11-05-2012, 12:01 AM #1
jman11788's Avatar
jman11788 jman11788 is offline
jman11788 is on a distinguished road
jman11788's Avatar
Are these bumpstops?
Ok in the rear springs what are the big rubber things inside them called? I'm wondering if they're bumpstops or something else, maybe to help tow or what? Because those things are pretty close on touching the bottom part which makes the rear very bumpy. Would it be ok to take them off?
2000 Limited 4wd Supercharged with E-Locker
jman11788 is offline   Reply With QuoteReply With Quote
Old 11-05-2012, 12:06 AM #2
Kurtis's Avatar
Kurtis Kurtis is offline
Kurtis is on a distinguished road
Kurtis's Avatar
Can you get a picture? This would help a bunch!
My Junk
Kurtis is offline   Reply With QuoteReply With Quote
Old 11-05-2012, 12:16 AM #3
jman11788's Avatar
jman11788's Avatar
Ok this isn't mine but the one in the right is what i'm talking about. I know the left one is a bumpstop, so why would there be 2 of them??
http://www.4x4wire.com/toyota/4Runne...bump_stops.jpg
Old 11-05-2012, 12:31 AM #4
AZTOY's Avatar
AZTOY AZTOY is offline
AZTOY is on a distinguished road
AZTOY's Avatar
Yes it is a bump stop for spring compression. I took mine out when I put on my Sonoran Steel rear lift.
97 V6 4X4 AT; ICON 2.5 EXT TRAVEL COILOVERS / SS 1.2 REAR; AUSSIE LOCKER; TC UCAs; SAVAGE OFFROAD SLIDERS AND SKID PLATES; ARB BUMPER; WARN WINCH; LOTUS CONTROL ARM SKIDS; DECKPLATE/ISR; 265/75/16 BFG KM2
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
AZTOY is offline   Reply With QuoteReply With Quote
Old 11-05-2012, 12:38 AM #5
jman11788's Avatar
jman11788's Avatar
So if i dont do much towing or anything it would be ok to take them off?
Old 11-05-2012, 01:07 AM #6
02_SE_Runner's Avatar
02_SE_Runner 02_SE_Runner is offline
Real Name: Nate/Nathan
02_SE_Runner is on a distinguished road
If you take them off you would be taking out a support that is holding up your truck. Eventually your spring will have no more "spring to it" and your ride quality will be crap. I would strongly suggest getting new springs, or for a temp fix, assist bags. The picture that you posted looks like the spring is at the end of its life. Imagine if you take out the cone, your suspension will still be halted by the axle bumpstop.
The Name is Nate. (n8) I own a 2002 4Runner Sports Edition. Feel free to PM me, about anything.
My Build: http://www.toyota-4runner.org/3rd-ge...od-thread.html
02_SE_Runner is offline   Reply With QuoteReply With Quote
Old 11-05-2012, 01:13 AM #7
jman11788's Avatar
jman11788's Avatar
The picture is not my vehicle. With nobody in the car the bumpstops are about half an inch on hitting
Old 11-05-2012, 02:49 AM #8
Royisme Royisme is offline
Royisme is on a distinguished road
You're in pretty desperate need for some new springs. If you remove them, and then hit a pothole, instead of rubber being the item that makes contact, it will be metal on metal. With that kind of inertia, it won't be long before you either dent/bend the axle housing or cause some frame damage. Either way, you're talking considerably more money than what it would run to have some new springs shipped to your door.
1980 Toyota Pickup SR5, 4x4 w/20r - Kept stock & sold
1984 Toyota Pickup, Extra Cab, 4x4 w/22R - Lifted, wheeled, broke, fixed, wheeled, broke (that repeats a lot for this one...) sold.
1986 Toyota Pickup SR5, Extra Cab, 4x4 w/22R-E - Kept stock & stolen
2000 Toyota 4Runner SR5, 4x4 w/5VZ-FE - Keeping mostly stock... plans TBD.
Royisme is offline   Reply With QuoteReply With Quote
Old 11-05-2012, 04:45 AM #9
AZTOY's Avatar
AZTOY's Avatar
I would NOT recommend taking out the spring bump stop in your situation. I only took mine out because Sonoran Steel recommended it when I lifted it. Are your springs sagging?
Old 11-05-2012, 05:24 AM #10
4x4runner2002's Avatar
4x4runner2002 4x4runner2002 is offline
4x4runner2002 is on a distinguished road
Not to thread jack but did you put something else at the top of the new spring or is it just metal on metal up there.
4x4runner2002 is offline   Reply With QuoteReply With Quote
Old 11-05-2012, 05:30 AM #11
AZTOY's Avatar
AZTOY's Avatar
I didn't put anything in there beside the LC springs that come with the SS lift. I have not noticed any sounds or ill effects. It seems to be a common practice with LC spring lift.
Old 11-05-2012, 05:35 AM #12
Thanks for the reply. I recently did the 891 lift and left them in. I did a little research but couldn't find any conclusive answers.
Old 11-05-2012, 09:57 PM #13
jman11788's Avatar
jman11788's Avatar
If those ar bump stops then how come they put 2 kinds of bumpstops in the rear?
Old 11-05-2012, 10:08 PM #14
Gerdo's Avatar
Gerdo Gerdo is offline
Gerdo will become famous soon enough
Gerdo's Avatar
The arched rubber pieces on the frame are the bumpstops.
The cones inside the coils are Jounce bumpers. They are there to carry the load when loaded down. If you are going taller coils, the chances of loading to the point that they would be needed is slim. While wheeling, these can limit compression. The removal of them allows the steel coil to ride on the steel coil bucket on top. I don't like that option. Also removing them reduces lift by about 3/8". I have kept mine in but cut a couple of donuts off each.
2000 4runner Sport, SAS/4wheel Underground 3 link, Diamond axle, 14" Radflo coilovers, double locked, Custom rear 3 link, 12" Fox shocks, full armor Gerdo's Build Thread
Real Fuel Tank Skidplates for sale Lil' Skip's OffRoad
Rear control arm mount skids and Hi-Lift adapter for sale Lotus Development
Gerdo is offline   Reply With QuoteReply With Quote
Take off bumpstops? jman11788 3rd gen T4Rs 6 07-07-2012 11:07 PM
WTS -New FOX Racing 2.0 Bumpstops W/ Cans SOcalTRAIL For Sale: Suspension/Wheels/Tires 2 02-24-2012 11:08 PM
Anyone have some stock 3rd gen Rear Bumpstops? J-money$$$ 3rd gen T4Rs 7 11-07-2010 02:42 PM
whats best way to get rear bumpstops off? cordrayj1 3rd gen T4Rs 0 07-22-2010 02:52 PM
bumpstops w/ lc coils?? danjko888 3rd gen T4Rs 2 12-09-2008 10:27 AM
