Old 11-09-2012, 01:43 PM #1
cj80cruiser's Avatar
cj80cruiser cj80cruiser is offline
cj80cruiser is on a distinguished road
Adjusting Tundra 5100's
Installed my lift yesterday but didn't get the lift in the front I thought I would so I need to adjust the the collar up from the bottom perch up to about the middle. Has anyone used spring compressors like the ones you can rent from autozone with the coil assembly still on the truck?
Seems like it would be easier than taking the shock out and probably safer in case the spring compressors happened to slip.
Bonehead idea?
戦争イーグル
Cory J
Wheel converter,
cj80cruiser is offline   Reply With QuoteReply With Quote
Old 11-09-2012, 03:23 PM #2
Qyota's Avatar
Qyota Qyota is offline
Qyota is on a distinguished road
Qyota's Avatar
I don't think it's a bonehead idea, I'm just not sure if there is enough room to get the compressors in there. Would be pretty cool if it worked, though!
Qyota is offline   Reply With QuoteReply With Quote
Old 11-09-2012, 03:58 PM #3
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
That very well could work. There is also this method..which I have not done, nor do I recommend.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 11-09-2012, 04:18 PM #4
Bama_Runner's Avatar
Bama_Runner Bama_Runner is offline
Bama_Runner is on a distinguished road
I don't think you will be able to do it without taking it off the truck. I've used 5100s on three different trucks now (2 Tacomas and 1 4Runner) and I don't think you could get the compressors in there. I'm not sure how you went at taking your springs/shocks out, but put my jack under the lower control arm, then I loosen the lower ball-joint bolts (4 of them), loosen the sway bar end link and then the lower shock bolt and top hat bolts. Then lower the jack. I can do it using this method rather quickly. I used the method in the video above for my Tacomas but couldn't get the 5100s back in the 4runner without using a spring compressor.
2004 Limited 4WD / 2014 FJ Trail Team Springs and Shocks + Daystar 2.5" F and Fat Bob's 2" R / 1/2" Body Lift / Level 8 MK6 17x9 -12 / BFG All Terrain KO 265/70/17 / Hella 500 FF / Yakima Load Warrior
Bama_Runner is offline   Reply With QuoteReply With Quote
Old 11-09-2012, 04:30 PM #5
eightyhd's Avatar
eightyhd eightyhd is offline
eightyhd is on a distinguished road
eightyhd's Avatar
i used spring compressors from autozone to adjust the clamp up a notch without removing anything.
But i have a dewalt impact driver and it was a piece of cake.
My Build:
eightyhd is offline   Reply With QuoteReply With Quote
Old 11-09-2012, 04:31 PM #6
Yoter's Avatar
Yoter Yoter is offline
Yoter will become famous soon enough
Yoter's Avatar
I have attempted this method, After taking things apart I realized it was simply much more work than getting a spring compressor on the free 48hr rental from O'rielly's. (the spring compressors were not at all scary to use, granted that is a relative term)
In order to do the above method on a 3rd gen, you need:
A 22mm (I think its 22) wrench to loosen the lower A-Arm and then will need a torque wrench that will fit into the very confined space between the frame and A-Arm.
I realized that I would have no way to retorque the A-Arm and decided it was a bad idea.
As for using spring compressors while the strut is in the vehicle I also dont think this will work as you wont be able to place them 180deg. from one another. Causing the spring to bend unequally and not compress enough to move the 5100's up a perch. Also if the spring is compressed unequally on both sides you heighten the risk of the spring compressors slipping greatly.
2000 "The Silver Legacy 2" Highlander Edition, 5speed 4x4
2000 "The Silver Legacy" Highlander Edition, 5speed 4x4 RIP
1996 Stellar Blue 5 Speed Sold
Yoter is offline   Reply With QuoteReply With Quote
Old 11-09-2012, 07:29 PM #7
blonde1boarder's Avatar
blonde1boarder blonde1boarder is offline
Real Name: Andrew
blonde1boarder is on a distinguished road
Real Name: Andrew
Hey. First post on t4r but what I always do with spring compressors is rent two sets and throw 3 on in a triangle. Puts a little less stress on each individual compressor.
blonde1boarder is offline   Reply With QuoteReply With Quote
Old 11-10-2012, 05:02 AM #8
I used my part out truck as a spring compressor just like the video you have there. It worked very well and I felt fairly safe doing it that way since I could keep my distance.
If the spring compressors wont work like I want then I'll throw them back on the parts truck and do it that way.
戦争イーグル
Cory J
Wheel converter,
Old 01-15-2013, 07:20 PM #9
drabbits's Avatar
drabbits drabbits is offline
Real Name: Alex
drabbits is on a distinguished road
drabbits's Avatar
Real Name: Alex
This method worked out very well for me. Easy as apple pie and a hell of a lot safe than spring compressor rentals.
drabbits is offline   Reply With QuoteReply With Quote
Old 01-15-2013, 07:28 PM #10
shadow247's Avatar
shadow247's Avatar
I'm lucky that I have access to a real wall mounted strut compressor. I will try to make a video this weekend on how the pro's do it when I swap back to my 99 springs this weekend.
The 4Runner Show
Old 01-15-2013, 07:54 PM #11
I ended up taking one of mine to a friends shop where I got to see the wall mount compressor in action. Hands down the easiest way to get this done.
戦争イーグル
Cory J
Wheel converter,
Old 01-15-2013, 08:25 PM #12
shadow247's Avatar
shadow247's Avatar
Yeah I got pretty good at it when I put my lift on. I had to tear one side apart 2 or 3 times because I messed up my top plate. It was not fun, but now I am an expert at using one.
The 4Runner Show
Real life comparison: Tacoma 5100's vs Tundra 5100's quicksilvr 3rd gen T4Rs 61 06-28-2019 09:08 AM
Tundra 5100's thebrandon 3rd gen T4Rs 5 10-29-2012 01:22 PM
TRD Tundra/Bilstein 5100 Lift SCRunner12 For Sale: Suspension/Wheels/Tires 16 09-28-2012 12:56 PM
Tacoma or Tundra 5100's? hungryeddy 3rd gen T4Rs 25 12-18-2011 02:45 PM
tundra bilstein 5100's & bumpstops danjko888 3rd gen T4Rs 0 11-15-2008 12:15 AM
