Originally Posted by djtc
I bought a new toyota mass airflow.Yes it is dumping alot of fuel, i'm getting 8.5mpg
The scan tool is a cheap unit, I guess the equivalent to what you guys have a harbor freight
ahh, ok. Just to clear a few things up, when you scanned the car the last time, the engine was warm, correct? I just need to know if your ETC temp was correct. Also, it was about 60F outside, right?
I just watched the video's, but the first one doesn't have very good sound quality so I can't really hear what it's doing. The second one just sounds like a very excessive crank before it starts and then runs a bit rough. Next time it gives you a hard time starting like that, push the gas pedal and hold it all the way to the floor. I think it's loading up with fuel. Holding the pedal to the floor cuts fuel flow to the injectors. Don't pump the pedal, literally hold it to the floor and see if it aides in starting.
