Old 12-20-2012, 09:18 AM #61
Buckaroo's Avatar
Buckaroo Buckaroo is offline
Buckaroo will become famous soon enough
Buckaroo's Avatar
Perhaps the crank timing pulley tooth was broken when the pulley was removed. How did you get it off?
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
Buckaroo is offline   Reply With QuoteReply With Quote
Old 12-20-2012, 10:19 AM #62
mattman's Avatar
mattman mattman is offline
mattman is on a distinguished road
mattman's Avatar
hmm ... i don't want to seem pessimistic, but i don't see how the broken tooth or the chip broken off the pulley would stop it from running.
2000 4Runner SR5
231mm brake upgrade
KYB shocks
2002 4Runner SR5
99 Tall Coils w/ KYB shocks
mattman is offline   Reply With QuoteReply With Quote
Old 12-20-2012, 04:10 PM #63
Buckaroo's Avatar
Buckaroo's Avatar
I think that the purpose of the teeth is to provide crankshaft position info to the crankshaft position sensor. It is the tone ring for that sensor. If one of the teeth is broken, the signal from the CPS to the ECM would be momentarily incorrect. I suspect that this could have multiple symptoms ranging from engine running rough to stalling out. Maybe someone who knows for sure could comment. It is possible that the tone ring for the crankshaft could have been damaged like this if the timing pulley was levered off the shaft from behind.
I agree that the cracked harmonic balancer is likely not the cause of this issue although it could very well damage the drive belt.
2004 Honda Accord
Old 12-20-2012, 07:58 PM #64
1blink 1blink is offline
1blink is on a distinguished road
Prying off the timing pulley certainly could break a tooth if not done carefully. It's been a month, but I seem to recall it coming off by hand without prying. Who knows.
My local dealership's master mechanic confirms having seen the same problem post-timing belt replacement, caused by a broken tooth on the timing pulley.
New crank timing pulley is on, belt all lined up. URD lightweight pulley should be here tomorrow!
engine starts, immediate stall after timing belt job-2012-12-20-17-37-52-jpg
215k+ 1997 SR5 manual, e-locker, + stuff
1blink is offline   Reply With QuoteReply With Quote
Old 12-20-2012, 09:44 PM #65
mikebontoft's Avatar
mikebontoft mikebontoft is offline
mikebontoft is on a distinguished road
depending on the type of tone ring, if it's bent the computer will not see the correct signature and pretty much be lost on where it is. Just saying, it doesn't have to be broken to be a problem.
'94 SR5 V6, 2" body lift, 4.56 gears, 31x10.50-15, Hella 500's (needs less stock!)
Originally Posted by KidVermicious View Post
I wouldn't be opposed. With another kid on the way, four doors is looking more and more attractive.
mikebontoft is offline   Reply With QuoteReply With Quote
Old 12-22-2012, 08:51 PM #66
Pulley is on, torqued it down and test started. Seems that was the ticket.
As I was torquing down the fan mounting bracket tonight, one of the studs stripped it's threads. Stuck waiting on parts again. Xmas is in the way, will probably add a few days to my order.
engine starts, immediate stall after timing belt job-dsc08002-jpg
Old 12-28-2012, 01:37 AM #67
Got her all buttoned up today after work...took it to the store to pick up a few things. 6 weeks without my truck....man did i miss her.
I learned a whole lot about engines and repair during the process, no regrets. Thanks for all the suggestions along the way. Now, on to the next mod!
engine starts, immediate stall after timing belt job-mail-google-com-jpg
Old 12-28-2012, 02:10 AM #68
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Glad to hear that it is back on the road.
I have never seen a URD pulley before; it looks quite nice.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 07-18-2019, 11:30 PM #69
eanema eanema is offline
eanema is on a distinguished road
Digging up a 7 year old post just to say that I had the same problem. Turns out I somehow broke a tooth off too. But not just any tooth, the exact same tooth as 1blink. Strange thing, I didn't pry it off, I used a puller to get it off, so i have no idea how I broke it.
Anyway, thanks for taking the time to figure it out for the rear of us. I ordered the new pulley and it started up like a champ... A week and a half later >:-( stupid Amazon
Sent from my Pixel 2 using Tapatalk
eanema is offline   Reply With QuoteReply With Quote
Old 09-27-2021, 07:21 PM #70
NC-Limited NC-Limited is offline
NC-Limited is on a distinguished road
Sorta the same issue. Finished the belt and water pump install now the engine just turns over but will not fire up.
Also sorry for waking up a old post. If I need to move it let me know
NC-Limited is offline   Reply With QuoteReply With Quote
Old 09-28-2021, 09:08 AM #71
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Check that your crank position sensor connector and camshaft position sensor connector are connected and completely engaged (clicked in all the way). If they are, does your rpm gauge show anything while cranking?
In trouble: Chg'd Timing belt & engine locks up when hand rotating Psheehy 4th Gen T4Rs 16 03-11-2012 12:02 PM
timing belt - interference engine? northernT4R 3rd gen T4Rs 4 06-30-2011 12:55 AM
Timing Belt Tensioner: Should I replace it when doing the timing belt change? Lugnutz 3rd gen T4Rs 14 05-12-2011 12:58 PM
1999 limited 5vz-fe engine timing belt write up shootmymime Maintenance/Detailing 1 09-05-2008 09:16 AM
Engine Louder after Timing Belt Replaced BuckeyeBrewer 3rd gen T4Rs 0 05-31-2007 11:05 AM
