11-18-2012, 06:33 PM
Real Name: Ben
Real Name: Ben
what gear ratio
ok so i have a DD that will see trails. will be running a 33 to 34 in tire and wondering if i should go with a 4.56 or a 4.88?
11-18-2012, 07:05 PM
Stock is 4.10 or 4.30 depending on year and elocker. So going to a 4.56 wouldn't be worth the price tag. My vote would be for 4.88 or 5.29
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
11-18-2012, 07:09 PM
Which engine and transmission?
11-18-2012, 07:59 PM
Real Name: Ben
Real Name: Ben
Oh yeah sorry it would be a 2001 with a 3.4 and I believe a340 and no locker. Will be using an arb or zip in the rear. The stock tire on the tag is a 225.
11-18-2012, 08:12 PM
Real Name: Rob
Real Name: Rob
Sounds like my stock tire size... You're prob geared at 3.9 right now. I'd vote 4.88's.
11-18-2012, 09:02 PM
Real Name: Ben
Real Name: Ben
I have 265/75r16 right now and it seems sluggish as compared to where it should be so I am upping to a better ratio. So what would the adverse side of going 5.29 be?
11-18-2012, 09:11 PM
Real Name: Russel
Real Name: Russel
If I'm not mistaken...2001 without a locker, you should have 4:10's from the factory. I'm in the same boat...I have 4:10's and I just put on a set of 33's. I'm been trying to decide what gears to go with also. At 65 mph, I'm only turning 2000-2050 rpm's. I'm thinking 4:88's will be good. I don't to low cause this is my DD too. I'm trying to find one of those charts that shows you which gears to run with what tires and at what rpm's. If I find it, I'll try and post it for you...
11-18-2012, 10:32 PM
Real Name: Ben
Real Name: Ben
I am right about at 2100 at 65 so that would make sense. I will probably go with 4.88. And that would be awesome and definitely helpful.
Anyone heard anything about zip lockers?
11-19-2012, 12:30 AM
Real Name: Bryan
Real Name: Bryan
here is a link to gear chart hope it helps Lift Kits, Tires & Wheels by 4 Wheel Parts
11-19-2012, 12:49 AM
Real Name: Ben
Real Name: Ben
That helped a ton. Thanks for the help bud
11-19-2012, 08:47 AM
Hi, actually im doing the same. I have already decided for 4.88 by suggestion from trail-gear.com but im afraid of get the wrong parts (10000 km shipping), for the front diff overall.
I have 1KZ-TE engine, don´t know about transmission.
A friend told me the original gear its 4.1 for sure.
Can you help me?
El Seba
1998 SW4 Limited "La iguana"
11-20-2012, 04:50 AM
Real Name: Ben
Real Name: Ben
What year? And you might check out ringpinion.com it is selectable by axle and as well inchworm (google it) is another good reference.
11-20-2012, 01:35 PM
Thanks a lot, its a 1998 4runner, here in Argentina also called SW4 and the most popular engine was the 3.0 Tdi. Rear Diff its ARB and in the front sure it´s the 7.5" you told me. So i expect dont make a mistake, there shouldnt be such differents from yours.
Thanks for the links.
El Seba
11-20-2012, 05:03 PM
Real Name: Ben
Real Name: Ben
Ok that helps a lot will check it out for u
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Gear ratio?
alejo2112 |
4th Gen T4Rs |
6 |
12-05-2019 03:32 PM |
gear ratio?
lincolndriver |
Classic T4Rs |
14 |
08-04-2010 06:53 AM |
need help with gear ratio.....
hdoggie24 |
3rd gen T4Rs |
1 |
01-02-2010 02:53 PM |
gear ratio
4runnerhyde |
4th Gen T4Rs |
1 |
08-31-2006 01:19 AM |
Gear Ratio
smccollamjr |
3rd gen T4Rs |
8 |
11-19-2005 10:10 AM |
