Originally Posted by sierra_summits
So i think i have settled on the toytec lift with 906 out back! Stoked! But is there other shiznat thats easy to replace while doing the lift?.... Sway bar bushings, bump stops, tie rods, UCA bushings? I dont mind upgrading stock parts even if they r not worn out so that i dont have to get back in there. Just looking to create a great ride! Opinions? thanks for any help.
Summits
Buncha stuff..... you could do the tundra brake upgrade (that should be your #1), replace all ball joints and TRE's, sway bar bushings if you want. You wouldn't need to replace bump stops with 906's... you could replace CV's if you feel the need. Install a diff drop as well.
