Can these parts even be purchased? I need the exact same part as you never want to adjust these headlights when they are old. :-( Or I am stuck buying an entire headlight for these adjuster parts as it seems the rust belt is a little hard on the plastic and the metal screw adjuster.
As good old Tetanus 1 has a old empty rule of electrical tape and silicone holding the headlight adjuster together.
The Dealership doesnt even have these parts listed in their diagrams and I went into toyodiy.com and found the headlight just see that part listed
found the bolt with washer
Headlight assembly nut
and the grommet for the side marker push pin but sure seem to be coming up negative on those adjusters and those holding plastic grommets.
Anybody have them or know of a A/M source for new ones?
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
