12-07-2012, 12:41 AM
Real Name: Zane
Real Name: Zane
Tundra Adjustable Bilsteins: amount of lift for stock height springs?
Hey guys, I tried searching, but it seems that everyone who gets tundra billies runs them with tundra coils, or some other kind of coil that adds lift. Im wondering if anyone knows how much lift each notch on the adjustable tundra billies will net with stock-height springs. I'm wanting around 2.5 inches of lift from the shocks. Just curious what notch to set them to, to gain this amount.
Thanks in advance!
OLD - "Miss Molly Brown" = '96 Limited 4WD - Anthracite Metallic - 265/75/16 Cooper Discoverer ATR - 4 Spidertrax 1.5" Wheel Spacers - 1 pair of Hella 700FFs
NEW - '06 SR5 V8 4WD - Shadow Mica - Gibson Exhaust - 265/70/17 BFG A/T KOs - Front= Bilstein 5100s set at top notch - 2011 FJ Trail-teams coils - Toytec diff drop - SPC UCAs - Toytec swaybar relocates - Rear= Toytec Superflex coils - 2011 FJ Trail-teams Bilsteins
12-07-2012, 01:20 AM
Don't take this as a fact because I'm second guessing myself as I type this but I believe the 5100 perches act as a spring spacer when you get down to it. And I remember reading that a spacer doubles itself in lift. ie: a 1 inch spacer gives 2 inch of lift. So I'd think youd want whichever perch is about 1.25 inches higher then the bottom. But I'd wait for someone else to confirm.
1996 Limited 4X4 Desert Dune, 140,000 miles, E-Locker
About to get a 5-Speed r150f!
12-07-2012, 11:16 AM
I gots the 3-perch 5100's with stock coils. I believe the Tundra ones are 4-perch. First off, these shocks are slightly longer than stock so you will get a slight lift just installing them. I put mine on and left at lowest setting and got just under 1/2" lift. Anyway, if you put it on the highest perch, you'll get 2.5" of lift plus a little more due to shock length (still retaining the stock coils), roughly getting a total of 3".
'96 Limited - Locker - 127k- totaled out -
'01 Limited 175k - sunken and resurrected - stock, other than TBU 231mm
'98 Limited - Locker -158k-Bilstein 5100 Tacos- Toytec/Eibach 3" lift coils- diff drop-265/75/16 Duratracs -OME 890's-Bilstein 5125's, panhard bar drop, TBU 231mm, Spidertrax 1.25' spacers, Savage sliders, 2nd gen SC/URD 7th, JBA exhaust, HID retrofits -
12-07-2012, 06:33 PM
Real Name: Zane
Real Name: Zane
I'm looking for info on the Tundra billies, not the Taco billies. Where the confusion lies, is that the Tundra shocks are taller than the Tacoma shocks to begin with (or am I wrong here?), so I'm not sure how much lift the tundra shocks would net even on the stock-height notch, much less when you start bumping them up the range of notches...
12-08-2012, 07:07 PM
I just swapped mine yesterday, setting 5 with stock 99 coils gave me about 1/2" more than the Daystar 2.5" spacer kit, the ARB bumper lowered me about 1/2-3/4". I think these put me back to a true 2.5" over my stock. My hub center to flare is 23". ride is very nice. Hope this helps...
1999 SR5, Tundra 5100's with toytec 1/2" top mount spacer, OME 890, Bilstein 5125, Tundra 231's, Arb Bullbar, Smittybilt xrc8 comp, Burtman Industries spoiler, Procomp 7128 wheels, Procomp xtreme mt2 285/70r17 tires, Rola roof rack, smittybilt 20" led lightbar, e-locker w/ 4.30 gears, full savage offroad skids, lil skips gas tank skid, lotus control arm skids, 215k
12-08-2012, 07:15 PM
The bottom perch should be standard ride height. It is a little under twice the height gained per perch measurement. So if you raise the coil an inch, you will lift the rig a little less than 2".
This will explain more Top out spacers
2000 4runner Sport, SAS/4wheel Underground 3 link, Diamond axle, 14" Radflo coilovers, double locked, Custom rear 3 link, 12" Fox shocks, full armor Gerdo's Build Thread
Real Fuel Tank Skidplates for sale Lil' Skip's OffRoad
Rear control arm mount skids and Hi-Lift adapter for sale Lotus Development
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
