Old 12-10-2012, 04:02 PM #1
snowninja snowninja is offline
snowninja is on a distinguished road
P0301 code
went skiing this weekend and on the way up to the mountain the CEL started flashing then went steady on and off a couple times. I could feel a little shudder/stutter at lower RPM's but then I would throttle up and everything felt fine. same thing on the way home. today I took it to autozone to borrow the scanner and it stored 300 and 301 codes. 300 is general and 301 is misfire on cylinder 1. 4 options, injector, coil pack, plugs, wires. plugs and wires are a year old done at dealer. would think that if coil pack was bad 1 and 3 cylinders would misfire but maybe not? dealer wants $250 to replace #1 injector. How hard is this to do having never done it, I am pretty handy and have basic tools. I priced 2 different injectors from parts stores and both were around $100 so i'd be out about $150 to have the dealer do it. having never done this before would it take me more than a couple hours to do and what could I screw up along the way? I have a Chiltons and also access to a FSM.
funny thing is i got a can of carb cleaner put it in and drove it 10 miles home, no sputter or shudder or stutter.. AT ALL.. could that really have fixed it or just coincidence? i am going to take it on another hilly test drive right now..
snowninja is offline   Reply With QuoteReply With Quote
Old 12-10-2012, 04:06 PM #2
HCurphy's Avatar
HCurphy HCurphy is offline
HCurphy is on a distinguished road
HCurphy's Avatar
don't jump to injectors, thats too expensive.
Cheap things First. Plugs, Wires(i know there not that old, but still cheaper then doing an unnecessary injector) and swap a coil pack to another cylinder. Then see what happens, and report back.
edit: also make sure you have dual ground plugs, although if the dealer did them they should know that.
'96 SR5 2wd 275k miles
TBU 231's-Brembo Rotors, '99 Tall coils, Billsteind HD 4600 series, FJ Cruiser 17", 265/70/R17 Terra Grapplers [ all original other then tune-ups, oil changes, front o2, u-joints, and axle seals ]
Last edited by HCurphy; 12-10-2012 at 04:07 PM. Reason: added dual ground suggestion
HCurphy is offline   Reply With QuoteReply With Quote
Old 12-10-2012, 04:29 PM #3
ok will try this and report back, thanks
Old 12-10-2012, 05:21 PM #4
I have been pricing parts and none of the aftermarket parts stores have the dual ground NGK plugs, Toyota dealer has them (denso) for $6/each. I found a wire kit (wires and boots) at napa for $75 and Toyota has the kit for $83. so dealership total of $125 for all plugs, wires, boots. Is there a better place to get these or is the dealer the best option? They also have everything in stock so no need to order, wait, etc..
Old 12-10-2012, 05:24 PM #5
thor999 thor999 is offline
thor999 is on a distinguished road
I think most of us get them from amazon.com, probably not very helpful if you are in a hurry.
thor999 is offline   Reply With QuoteReply With Quote
Old 12-10-2012, 05:40 PM #6
jkoni426 jkoni426 is offline
Real Name: Joe
jkoni426 is on a distinguished road
Real Name: Joe
if you have a multimeter, you can check the resistance on the plug wires, injectors, and coils to see if they're in spec. better than throwing money at the problem hoping to fix it.
'99 T4R SR5 V6 4WD Imperial Jade Mica | 199mm TBU
jkoni426 is offline   Reply With QuoteReply With Quote
Old 12-10-2012, 05:56 PM #7
HCurphy's Avatar
HCurphy's Avatar
VJ whisperer has a good point (and hilarious username--that im kind of suprised was allowed)
If you have a multimeter you can check to see if coil, wires, and injectors are in the specified range, but I have heard/seen/read about both injectors and coil packs that tested in range and were still found to be the culprit. It's still worth it to check if you have the capability but is not 100% conclusive.
You could save about ten bucks on plugs, and (working on memory) about thirty bucks on wires if you can deal with the misfire while you order the parts you need from amazon. (thats NGK wires not OEM) In the meantime you could still move the coil pack for cylinder 1 to another cylinder and see if the misfire follows it.
It's kind of up to you though. You can almost always save money by buying from somewhere other then the dealer and doing the work yourself. For just plugs and wires(and switching a coil pack around) it looks like you could save about 50 bucks by not letting the dealer do it.
From the OP, it doesn't sound like the misfire is that bad. So, In my opinion I would order the parts and save some money. The misfire shouldn't hurt anything in the few days it would take for the parts to come in.
edit: try the free thing first, switch a coil pack you may not need plugs or wires
Old 12-10-2012, 06:15 PM #8
ok thanks guys, i'll look into the other places to save some money if I can. i do have an ohm meter and can test these things but i'll tell you that i bought a can of berrymans b12 injector cleaner put it in, have driven 20 miles now and the CEL light went off and it's driving totally normal (for) now. is it really possible that this has fixed the problem?? is it at all likely?? don't get me wrong i'll still test the parts but if i only had to spend $5 on some injector cleaner that will be the best Christmas present to old whitey - after all he has 278k miles on him..
Old 12-10-2012, 06:47 PM #9
HCurphy's Avatar
HCurphy's Avatar
yeah, sure it's possible. I hope it takes care of it. If it does solve it then you may have had an injector issue after all. Maybe you had one that was ever so slightly clogged. If it does go away maybe pick up another can in a week or so and run it through again, make sure you got it all.
Hope you're back on the road for good. Oh and Welcome to the forum.
Old 12-10-2012, 06:58 PM #10
thanks for the welcome HC. my wife offered to test it some more on her drive to work (about 40 miles roundtrip) today so if it holds, i'll chalk it up to dirty injector but I'm skeptical to say the least. will report back any changes and thanks all for the quick response!!
happy travels
1998 4Runner SR5, 375k
2011 4Runner LE, 165k
Old 12-11-2012, 10:18 PM #11
Its back. This is my daily driver so I decided to take it in. They swapped wires plugs and coil packs and the problem didn't follow any so it points to injector.. $250 to replace it failed tests. Recommend cleaning the other 5 which they send out to a shop to do. Claim they come back like brand new. $400 to do this. Water pump leaking I have never replaced timing belt. $675 to do this.. why do I feel like I'm getting raped..
Old 12-11-2012, 10:27 PM #12
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Forgo getting the injectors professionally clean unless you have the deep wallet for it.
$675 is cheap for the timing belt/H20 pump, at least for around here in DC/VA metro, where the cost is 2 1/2 times your quoted amount. But it needs to be done.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 12-12-2012, 12:25 AM #13
prospectator's Avatar
prospectator prospectator is offline
prospectator is on a distinguished road
Does it use any water whatsoever? I had a P303, cylinder 3 misfire that would come and go with no visible white smoke, but it did use a small amount of water. I did plugs, coil pack, injector and it would always return. Eventually at 227K the problem came and never went away. I had a cracked head. Hopefully that's not the case, but with 278K I wouldn't rule it out.
You can get a full set of OE re-man injectors off Ebay for around $120. I've gotten one and it looked new and worked great.
Click Here!!!!!!!!!!!
1997 SR5 V6 4X4, E-Locker, Total Chaos LT with Fox C/O and Fox 2.5 Bypass, LC 7.5 Wrap, LC TrekMaster shocks, 315/75R16 BFG KO2's on Limited wheels, 4:88 gears, Custom front bumper, Patco fabrications rear bumper, Patco fabrications custom rear arms
http://www.prospectator.com
prospectator is offline   Reply With QuoteReply With Quote
Old 12-12-2012, 10:57 PM #14
I didn't notice leaks but they said the coolant res was low.I hope not a bigger issue.. I opted not to do the other injectors and plan to buy a set and if another one goes I'll replace all of them.
Old 12-12-2012, 11:55 PM #15
PitbullRescuer's Avatar
PitbullRescuer PitbullRescuer is offline
PitbullRescuer is on a distinguished road
Injector swap isn't tough, you could do it in about an hour in your driveway.
I would actually recommend you pull all of them, send them to WitchHunter.com (which is in your area) and get the OEM injectors cleaned/rebuilt. Aftermarket injectors are garbage.
However, before going that route, pull the plugs and give it a compression and/or leak down test. You mentioned 4 possible causes, but you forgot number 5: compression. And with 278K miles, it's quite possible you may have a compression issue. Hope not, but it's possible.
'98 SR5 4x4, cheap DD http://www.toyota-4runner.org/3rd-ge...im-addict.html '99 SR5 Highlander 4x4/5 Speed... http://www.toyota-4runner.org/3rd-ge...eed-build.html '97 SR5 4x4/5 speed, another new project... http://www.toyota-4runner.org/3rd-ge...new-build.html '00 SR5 4x4, new project, stay tuned... http://www.toyota-4runner.org/3rd-ge...ld-thread.html '97 Limited 4x4, freshened up quite a bit... http://www.toyota-4runner.org/3rd-ge...d-3rd-gen.html '99 SR5 Highlander 4x4... http://www.toyota-4runner.org/3rd-ge...ce-thread.html
PitbullRescuer is offline   Reply With QuoteReply With Quote
My experience with P0301; Resolved. trd_4runnin 3rd gen T4Rs 37 06-09-2018 12:42 PM
4th gen 4runner V8 rough idle Misfiring p0300, p0301-p0308 aha2988 4th Gen T4Rs 9 04-10-2012 03:28 PM
Check engine light on: Code 24 and code 31 Clone of the Mean Classic T4Rs 3 06-19-2011 12:12 PM
My P0301 experience: nexrace 3rd gen T4Rs 20 08-05-2008 10:23 AM
Share my P0301 experience... thmpr 3rd gen T4Rs 0 04-06-2008 11:11 PM
