Originally Posted by Loki2043
Opie,
On my alignment report it shows the acceptable range for the castor is between 1.6 and 3.6. Do you have any advice for me to try to get them to readjust it to tighter spec?
I just re-read your first post and noticed you have a 96. The spec I quoted is for a 2001, so thats my mistake. Looks like you are within spec....
But if it was mine... I would argue that you are close the the opposite limits on either side. Especially the driver side. Im anal like that.
THAT being said... If you are satisfied with the handling characteristics, leave it alone? Castor does not effect tire wear.
EDIT: Do get some grease in the BJ's. Better safe than to assume they came loaded up from the factory.
