12-26-2012, 12:11 PM
Quick electrical question
I currently have two of the 35 watt HID (Kragen style-red outer ring) lights on my roof rack. Could I run 4 35 watt HIDs through the same 30 AMP relay? I'd like to splice the other to lights into the same wires going roof so I don't need to run anymore through the headliner. Does that make sense; haven't had any coffee yet and my 10 month old has a cold so sleep deprevation is making me a zombie.
thanks
98 4runner. L.A.M.B. (locked, armored, methanol injected & blown) URD 7th & 2.2 pulley, meth injection, ARB bumper & lockers, Warn 9.5xp winch, yukon 4.88 gears, rear disk conv, blah,blah, blah blah [B]SOLDB]
93 Hilux Surf, 3.0 kz-te, restoration in 3, 2, 1
12-26-2012, 01:02 PM
Equation to calculate the amps is W = VxI. W = watts, V = volts and I = amps. With a 30 amp relay you can take out W = 12 X 30 = 360 watts of power. If you are using a regular cubic relay (non OEM denso), I recommend, do not run max amps. With two 100 W halogen lamps, a 30 A relay (non OEM) got roasted!
Same here with my daughter!
12-26-2012, 01:37 PM
you can calculate max amperage draw by taking the total wattage (so, if you mean 4 total 35w lights, you will have 140w draw) and dividing it by the lowest voltage your battery will see. (the lower the voltage, the higher the draw). in this case I used 12v.
140w/12v=11.6 amps. so, yes. it's fine. wire in series-parallel. you have one big wire for all four providing power, and then tap into it for each light.
'94 SR5 V6, 2" body lift, 4.56 gears, 31x10.50-15, Hella 500's (needs less stock!)
Originally Posted by KidVermicious
I wouldn't be opposed. With another kid on the way, four doors is looking more and more attractive.
12-26-2012, 07:30 PM
X2. I run 3) 100W Halogens off a single 30A Bosch relay with no issues.
SOLD!99 SR5 V6 - SS 1.2 Lift, 1" BL, 231mm TBU, LTX M/S2s, Savage Sliders, Skids and Bumpers, Lots of LEDs, 70266 ATF Cooler with 5757 Gauge, Homemade Roof Rack, VHF & CBs, Various Off-Road Goodies '10 Trail Edition - WeatherBeaters, VentShades, Prodigy P3, TruCool 4589 ATF Cooler, E Rated LTX M/S2s, Booster Seats with a hint of kid puke '16 Tundra TRD SR5 - ATC Cap, AirLift Bags and WirelessAir Controller, Prodigy P3, LineX, E Rated Defender LTXs
12-27-2012, 02:22 AM
^^that is cutting it close though... about a 25a max draw.
12-27-2012, 02:34 AM
Don't HIDs pull more though when they are first fired?
Giant Motosports
12-27-2012, 02:44 AM
Yeah, the Bosch relay will run 30A all day but I just scabbed it in to make a trip in time.... 5 months ago... Got a switch from OTRATTW sitting on the bench and a 40A relay just for peace of mind. Just need the time to get her done.
