Originally Posted by PhdNPrerunners
Ya I turned them till I couldn't anymore. No they have regular hvac controls like the sr5
That's strange 'cause in your picture of your leds, none of them have the plastic "wedge" bottom. If I was home I could shoot you some pics. I have spare #24s and the Neo Wedge B. Going by the chart, They are the same kind that I used for my display on my auto climate control. But you said your HVAC controls work so that's a moot point.
About a month ago, I had one of my gauge LED go out. It was blinking on and off. Thought it wasn't resting in the cluster PCB so I hooked some small jumper wires to my battery positive and negative, and tested it and it worked on an off. Found that the tiny little resistor had broke away internally from the LED. I say this so that maybe you could test them before putting them back in the cluster. I'm sure your not putting it all back together again and then turning it on, (that would be stupid) but continually unhooking those five connectors on the back of the cluster is a pain sometimes.
Oh one other thing I just remembered, make sure the connection to the dash dimmer is hooked up also. Made that mistake also and had me wondering what the hell for a few minutes. Good luck!
