10-31-2015, 02:45 PM
#61
I'm in the process of swapping a few more LEDs in. I got the ash tray bulb in = perfect!
The transmission shifter, which says uses the same size bulb, is a much larger bulb.
In a 2001 limited, might the size for the transmission shifter bulb be different? It doesn't appear that the same LED will work - the base of the bulb I removed is 2x wider than the #74 base.
I know the chart don't lie, but...
These are the bulbs in question - from left to right (ash tray light, #74 LED, bulb removed from transmission shifter)
10-31-2015, 03:23 PM
#62
A few things I've noticed so far with my 2000: the two 74s behind the climate control panel look like ass with a single LED. Might try one of the 3 LED ones, or find a way to wire a couple strips back there because the hot spots are terrible. Same with the ash tray bulb, the single directional LED doesn't do well in there, and there's a green plastic window that isn't removable. The bulb I got from superbrightleds was too big for the shifter plate bulb and actually broke the bulb holder when I applied moderate pressure, so I've got to replace that, or go with a strip underneath. Got the ECT and rear window switch done too, and the ECT button has a hot spot due to the way the bulb sits off at an angle. So far, not very pleased with the results.
2000 SR5 Sport - 4EAT and E-locker, King 2.5s, EimKeith PCK, SPC UCAs, 33" KO2s on Black Rhino Boxer gloss gold 17x8.5, Savage/Lotus skids, 4xInnovations front bumper/sliders, Shrockworks bumper & tire carrier, Lil Skip Gas Tank Skid, Magnaflow Overland cat back
10-31-2015, 03:29 PM
#63
Another thing I forgot. The cigarette lighter ring appears to be a non-removable bulb from the little grey plastic base, which of course shattered from the pressure or me pulling on it with my fingers. The only one so far that has worked fine is the rear window switch.
Thus is the bulb that's given me the lackluster results:
12-01-2015, 11:49 PM
#64
OP/anyone:
For the three gauge bulbs - the chart states to use #24 bulbs, however, in the write up, you used #194 - which one of them would be the right bulb? - or both sizes will fit ?
Also, further in the discussion, it was mentioned that #74 might be used where #24 are required, but - no one confirmed it, can anyone confirm this?
In my case, I need to replace one of the gauge bulbs.
Thanks..
'99 4Runner, 3.4L V6, manual transmission, 270K miles on 04.01.16
All stock, bumper to bumper. I have kids, wife and a mortgage. No time, no money.
12-07-2015, 11:58 PM
#65
Just ordered all my LED's. I like the stock colors so it's gunna look the same.
12-08-2015, 12:19 AM
#66
Real Name: John
Real Name: John
There are no LEDs that look stock at least if your talking about the OEM green like in the gauge cluster.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
12-08-2015, 12:23 AM
#67
WRITE UP: climate control and dash bulbs 2000 limited
I meant same color combo. Not all one color like some guys do... OEM look.
12-08-2015, 12:27 AM
#68
Real Name: John
Real Name: John
Originally Posted by Lug1
OP/anyone:
Thanks..
#24 in the gauge cluster. Autolumination has a variety #24 bulbs with multiple led arrays on them. #74s are way too small.
12-08-2015, 12:31 AM
#69
Real Name: John
Real Name: John
Look at what?
12-08-2015, 12:33 AM
#70
That's odd. I didn't post that picture. Haha
12-08-2015, 12:52 AM
#71
12-08-2015, 07:30 PM
#72
Real Name: John
Real Name: John
I had those exact bulbs. They did the job but then I found these at autolumination
Instrument Panel Gauge Dashboard Colored Led Bulbs Lights Lamps
Go down to the 3x 5630 Samsung bulbs. I use those now.
12-08-2015, 07:57 PM
#73
Thank you sir... Just ordered them.
12-08-2015, 08:03 PM
#74
Real Name: John
Real Name: John
What color are you getting. I used white. Really shows off the colors
#75
Dang it!
