Originally Posted by BeastPradoT&T
Hey guys I know this is a really old thread but I'm looking to do this but I was wondering if the a3040le is the same a340e transmission? Externally I can see they are nearly identical except for the 4wd. But I also noticed the selector rod by the neutral safety switch is on the right side with the switch it self and on my kzj90 prado it's on the left side.
So my questions are, can the rods be swapped out? And is the 3040le just another reference for the a340e? They both come in the supra as well.
My transmission in the van has finally given up after 22 years....the last 3 years it's been slipping and the last 2 weeks it has been revving up to 3500rpm before moving slow lol. The filter is changed every year with oil, so I'm guessing the transmission has just finally died. The oil came out black last month, changed oil and same thing within a few days.
Thanks for any info.
The shift rod can be change from left to right by removing the side shift u don't want and then taking one out of the one that has ur correct side. There r so many versions of the A340 that to say, yes or no, too u without looking over which units u have.... u would need to take any answer u get with a grain of salt. One big difference u need to look at is ur units line pressure controlled by the ECU or just a cable, the VB can be change between many version to accommodate different swaps, U also need to look at the front pump to make sure u don't use a lower flow on a vehicle that needs the larger flow volume, I could go on and on but without having both units in front of me the variables are unkown.
