Old 08-31-2016, 03:49 PM #16
Tylerz71 Tylerz71 is offline
Tylerz71 is on a distinguished road
Good info, hoping my factory 99 trans never takes a dump, trans work is never fun
Tylerz71 is offline   Reply With QuoteReply With Quote
Old 08-31-2016, 08:22 PM #17
88toy4x4 88toy4x4 is offline
88toy4x4 is on a distinguished road
Originally Posted by absalom View Post
I'm going to pull up pinouts in the wiring diagram, but in the meantime do you recall if there's any wiring differences between the F and E?
Not sure if this helps, but I did a 4x4 swap on my 2000 and the transmission plugs were identical between the a340e that I pulled out and the a340f that went back in. I believe the a340f was a 2000 model as well. The computer doesn't know the difference and it shifts like it did when it was 2wd.
2000 4Runner SR5 V6 - Was 2wd, now new and improved with 4wd!
- Tundra 199mm brakes, Front(99 Talls/Tundra 5100 at 3rd notch), Rear(OME 906/2-10mm trimpackers per side/Tundra 5100), Trail Gear Rock Defense Taco Crossmember, Taco 5-Stars, 265/75/16 Cooper ATP, DRL disable, ADD Switch, B&M 70268 Trans Cooler
- Next on the list: E-locker swap(hopefully), Better front skid
88toy4x4 is offline   Reply With QuoteReply With Quote
Old 08-31-2016, 08:24 PM #18
absalom's Avatar
absalom absalom is offline
Real Name: Jordan
absalom has a spectacular aura about absalom has a spectacular aura about
absalom's Avatar
Real Name: Jordan
That's fantastic to hear! Now, I'm somewhat concerned on how to deal with the kickdown cable. I understand the 00-02's don't have one, was this true for yours as well?
absalom is offline   Reply With QuoteReply With Quote
Old 09-01-2016, 12:08 AM #19
The 01-02 years are the models that don't have the throttle cable to the trans. That is when they switched to the drive by wire throttle body and added the servo in the transmission to control the line pressure. The last year for the throttle cable to control line pressure was 2000.
This older thread shows pictures with the differences between the valve bodies for all years.
2000-02 A340F vs pre-00
Old 09-01-2016, 12:36 AM #20
absalom's Avatar
Real Name: Jordan
absalom's Avatar
Real Name: Jordan
So I guess my question is, do I need a pre 00 trans or an 00-02 trans?
Old 09-01-2016, 08:09 AM #21
I would suggest using a 00 or older with the cable. I only suggest that due to the 01-02 models are using the ECM to control the line pressure servo. Unless that is built in to the trans controller that you are wanting to use(from the title of your other thread), then the older trans would be the easier to adapt to what ever you are doing. Less electronics to deal with.
Old 09-01-2016, 12:42 PM #22
absalom's Avatar
Real Name: Jordan
absalom's Avatar
Real Name: Jordan
Good stuff. I know need to figure out how control a kickdown cable with a drive by wire, as that's what I'll be transplanting into the truck.
Old 10-30-2016, 05:41 PM #23
pcr777 pcr777 is offline
pcr777 is on a distinguished road
Is it possible to just change out the solenoids in the valve body? My son has an '01 2WD 4Runner stuck in some higher gear (when not popped into neutral). He limped it into a parts store. They read a transmission solenoid fault code. Do they go bad and are they changeable? Any insight would be appreciated.
pcr777 is offline   Reply With QuoteReply With Quote
Old 08-09-2017, 10:42 PM #24
Kawaii055 Kawaii055 is offline
Kawaii055 is on a distinguished road
Does anyone know the part number for the 4wd shaft? It seems like every one I see on toyita parts sites are the long-splined 2wd ones. Is the schematic wrong? Thanks
Kawaii055 is offline   Reply With QuoteReply With Quote
Old 07-26-2018, 03:11 AM #25
BajaRated BajaRated is offline
BajaRated is on a distinguished road
Smile
Awesome write up! Just what i needed
BajaRated is offline   Reply With QuoteReply With Quote
Old 07-24-2021, 05:04 PM #26
vegask vegask is offline
vegask will become famous soon enough
Old thread I know. But isn't cutting the output shaft on the A341E an option instead of doing the shaft swap?
I am researching a 1UZ swap into a 3rd gen.
SAS 97 4runner / Bone stock 2005 4runner / aka "Kurtfab"
vegask is offline   Reply With QuoteReply With Quote
Old 07-24-2021, 09:50 PM #27
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
Absolutely not.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
Old 07-26-2021, 03:51 PM #28
Bad Luck Bad Luck is online now
Real Name: Patrick
Real Name: Patrick
Take a look at the photos in the first post and you'll see one with the E and F output shafts side by side. The F shaft is shorter than all the splines on the E shaft.
Bad Luck is online now   Reply With QuoteReply With Quote
Old 07-26-2021, 04:09 PM #29
That pic of the two shafts has me scratching my head. Cause I have seen a few videos where they just cut the shaft and drill for fluid passage and it works.
Like this one: Converting a Lexus A340e to 4WD - YouTube
Or I am over looking a detail somewhere.
Old 07-26-2021, 05:37 PM #30
Real Name: Patrick
Real Name: Patrick
The extension housing in the video looks very different from the extension housing on the A340E's that come in the 2wd 4Runners. If you pause @ 46 seconds in the video and compare it to the photos in the first post you'll notice the video extension housing looks much shorter vs the ones in the photos here.
A340E to A343F swap mmml4 3rd gen T4Rs 14 11-25-2012 09:54 PM
transmission resource for AT A340E cometobanks Classic T4Rs 0 03-17-2011 09:17 PM
A340F transmission quirks RescueMonkey 3rd gen T4Rs 1 01-06-2011 11:23 AM
Need A340F transmission 3rd gen Kevs442 Classifieds - buy & sell (no commercial ads please) 0 09-02-2010 10:38 PM
a340e transmission- answers quickly please! ALLNAMESTAKEN91 Classic T4Rs 1 10-19-2008 08:12 PM
