Old 07-27-2021, 06:18 PM #31
Originally Posted by vegask View Post
That pic of the two shafts has me scratching my head. Cause I have seen a few videos where they just cut the shaft and drill for fluid passage and it works.
Like this one: Converting a Lexus A340e to 4WD - YouTube
Or I am over looking a detail somewhere.
The 4Runner (errr, truck) uses a slip yoke output which has a different spline setup than the "car" version of the A340E. The 'car' version uses a 3-bolt flange that bolts to a guibo, and that has a more compatible extension housing and output shaft for converting to 4WD.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-02-2022, 07:04 PM #32
BeastPradoT&T BeastPradoT&T is offline
BeastPradoT&T is on a distinguished road
Hey guys I know this is a really old thread but I'm looking to do this but I was wondering if the a3040le is the same a340e transmission? Externally I can see they are nearly identical except for the 4wd. But I also noticed the selector rod by the neutral safety switch is on the right side with the switch it self and on my kzj90 prado it's on the left side.
So my questions are, can the rods be swapped out? And is the 3040le just another reference for the a340e? They both come in the supra as well.
My transmission in the van has finally given up after 22 years....the last 3 years it's been slipping and the last 2 weeks it has been revving up to 3500rpm before moving slow lol. The filter is changed every year with oil, so I'm guessing the transmission has just finally died. The oil came out black last month, changed oil and same thing within a few days.
Thanks for any info.
BeastPradoT&T is offline   Reply With QuoteReply With Quote
Old 03-02-2022, 07:22 PM #33
clearock clearock is offline
clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice
The shift rod can be change from left to right by removing the side shift u don't want and then taking one out of the one that has ur correct side. There r so many versions of the A340 that to say, yes or no, too u without looking over which units u have.... u would need to take any answer u get with a grain of salt. One big difference u need to look at is ur units line pressure controlled by the ECU or just a cable, the VB can be change between many version to accommodate different swaps, U also need to look at the front pump to make sure u don't use a lower flow on a vehicle that needs the larger flow volume, I could go on and on but without having both units in front of me the variables are unkown.
clearock is offline   Reply With QuoteReply With Quote
Old 03-02-2022, 09:03 PM #34
I will post some pics of both tomorrow. Thanks.
Only thing I know is the transmission I'm getting is from the aristo non vvti 2jzgte. It has the kickdown cable. One of the oil cooler lines has a temp unit.
Old 03-03-2022, 03:14 PM #35
The output shaft and housing will not match the 4Runner (uses a 3-bolt guibo flange instead of slip yoke or stub shaft for a transfer case). The bellhousing and torque converter, pump etc. is probably also different.
You can likely mix and match parts, but it will be some work.
Old 03-06-2022, 11:55 AM #36
The a3040le I was getting can't work as it uses a 5 solenoid and no kickdown cable. I would have to reuse my valve body which I don't want to for age reasons.
So the a3040le or a340e with the kickdown cable and 3 pin solenoid jack is the one I need to use.
I have already scrapped out my a340f and removed the output shaft, just waiting for a a340e cable type to start the process. Everything so far is simple, well I'm a mechanic but this is the first time I'm going inside an auto trans.
I could just rebuild it as to me it's not complex, but would take a longer time as I'm picky with cleanliness and making sure everything is done correctly.
Old 04-07-2022, 07:47 PM #37
So I got a correct transmission, it's an a3040le well so far all that I've seen is a3040le coded. 1jzge and gte as well as 2jzge and gte. The ones with the kickdown cable had the neutral switch on same side as my prado one as well as same 3 pin solenoid jack and valvebody.
I'm just waiting for front and rear prop shaft seals, the input shaft seal in the casing and a seal and bearing in the adapter housing case. Want to get the transfer case finished before I start the transmission work of swapping output shafts.
Here in T&T it's very difficult to find and I'm not find it in the U.S as my parents live in Nashville. If I can find it online, I would let them ship it to me.
Old 05-04-2022, 10:09 AM #38
So I got everything running and had to drop the trans again as the oil pump seal was leaking and I lost all my oil.
Put it up using my old torque converter and I think that might have been a mistake. I'm not getting a slow moving van on L 2 and D doesn't matter and Have to rev it up to start moving. Once it moves, it works normal until stopping again. Reverse works perfect however.
Any clues? Could it be a quart or 2 low on oil? Oil is cherry red and clean
Old 05-04-2022, 09:41 PM #39
So I dropped the transmission again and I'm seeing a burnt destroyed bearing in the overdrive support. The others behind looks good.
I'm guessing this was due to oil leaking out without me knowing until the van starting feeling like it was low on oil and this caused extreme heat to damage that bearing and race.
I'm planning to pull out everything and clean it up and mount it back up with my old overdrive support and bearing and race as well as scrap the valve body to clean it one time. Unless there may be another way to clean the valve body channels?
A340E to A343F swap mmml4 3rd gen T4Rs 14 11-25-2012 09:54 PM
transmission resource for AT A340E cometobanks Classic T4Rs 0 03-17-2011 09:17 PM
A340F transmission quirks RescueMonkey 3rd gen T4Rs 1 01-06-2011 11:23 AM
Need A340F transmission 3rd gen Kevs442 Classifieds - buy & sell (no commercial ads please) 0 09-02-2010 10:38 PM
a340e transmission- answers quickly please! ALLNAMESTAKEN91 Classic T4Rs 1 10-19-2008 08:12 PM
