iswing - If you are talking about "slop" in the steering wheel vs. actual steering movement, check / adjust the steering rack guide.
I replaced no parts, but did disassemble to have a look. When you check it, have someone inside moving the steering wheel back & forth. You'll be able to feel the play by holding the rack shaft (hold the drivers side rack boot) as the help saws on the wheel. I adjusted until that play was gone.
Good read here:
How to: Replace steering rack guide- Pictures
