05-15-2014, 10:07 PM
#61
Per side when I'm done I should have one grade 8 bolt in the welded end-cap with a welded and gusseted stand-up on the winch tray. One grade 8 bolt from the side, like yours. The small grade 8 bolt into the frame body mount gusset (pictured). Lastly, the two grade 8 bolts that hold the tow hooks will pass through a welded extension to the winch channel.
I'm really trying to avoid a permanent mount so I can still disassemble the front clip when I do timing belt and water pump. You think this still leaves weakness?
-2015 SR5 Premium - 2.5 inch lift w/BFG KO2's
Bilstein 5100's
-2005 Limited V8 (sold)
-1997 4Runner LtdS/C with URD 2.2 and meth
Lifted and locked
05-16-2014, 02:11 PM
#62
I put atleast two 1/2'' welds top and bottom that i could grind off if needed. I can jump up and down on mine, i have pulled out full size trucks, trees, myself. never moved even a little. I am confident in the set up.
The valance has to be cut away just about all the way.
E-Locker, Bilstein 5100,LX 450 Coils, Tundra Wheels Graphite, 33'' Duratracs, 1.5" wheel Spacers, Energy Suspension Sway Bar Links and bushings,Roll Bar, LED's, Sport Hood! XRC 9.5k Comp Winch Custom Mounted, 3rd Row Rumble Seat, B&M Tranny Cooler, Tundra Brakes, 4XInnovations Sliders, Uniden 520XL Pro CB, 4' Firestik.
My Build Thread!!
http://www.toyota-4runner.org/3rd-ge...8-limited.html
05-16-2014, 09:49 PM
#63
I'll update then process later but here is the finished product. I did end up welding to the frame too.
Bilstein 5100's
Lifted and locked
05-16-2014, 09:50 PM
#64
The oil is from me switching out the trans cooler....
Ended up with 8 - grade 8 5/8 inch bolts plus a 1 inch weld on the trailing arm of the plate to hold it. It's over-kill really but I like the looks.
Bilstein 5100's
Lifted and locked
07-20-2014, 04:14 PM
#65
So, lucky me, a metal smith friend, who also happens to enjoy wrenching, really wants me to do this to my Runner. I'm taking the bait, especially with the memory of the $550 backcountry towing bill from last year still very fresh in my head.
My one big question is, if we're going to follow your lead, do we have to go with that exact winch? I've never owned or even used a winch, but we're just curious about fit, etc. I've found the X20 8 w/ synthetic line for about $549 on Amazon. Just curious if that's a good price, because otherwise it seems that people like this winch a lot here.
Can't believe I'm doing this. Woot!
2004 Sport Edition V8. 3" OME lift. 5th Gen Brakes. 285/70 Duratracs. JBA UCAs. SCS Ray10s. DT Headers.
1997 4-Runner Limited w/ factory locker. Totaled in February 2018. Still miss it.
07-20-2014, 04:16 PM
#66
Originally Posted by geohil
Gotta bring this thread back to life...
My turn!
Not done yet but here is my start.
Started with stock - added Badland winch plate. Cut tabs and mounted with 4 grade 8 bolts. Tomorrow I'm welding the end caps and a 90 degree to the plate. Also trying to fit the Piaa's. This took me 4 slow hours and I feel like I should be done. Enjoy
That looks awesome. Which PIAA's are those? I'm thinking of doing similar, but I don't have a great budget for the lights.
07-21-2014, 10:30 AM
#67
Those are an older pair of Piaa 520's. They fit like a glove in there, but you could get away with any 6" light probably.
For approach angle switch to a Hawyse fairlead as well.
Bilstein 5100's
Lifted and locked
07-22-2014, 07:52 AM
#68
I am not sure if you have to use that exact winch. I know that I will be switching mine out soon for one with synthetic line and it's a little different than my current one. When are you planning on doing this?
My Build Thread!!
07-22-2014, 07:54 AM
#69
Oh by the way. The hawse lead looks nice. I just snap a plate on with mag light holders riveted to it to the current fairlead on mine. Here is a pic from the weekend on my own personal trails.
My Build Thread!!
07-22-2014, 10:27 AM
#70
That looks great! I've been running without a front plate...which is a no-no in my state so I'll have to add something like that too.
The X20 is a bit bigger than the XRC8 so you might have to do some more "persuading" to tuck it in there. If I had to do it over I would go with the XRC 9.5k. Synthetic rope and a bit more tug than my 8k.
Bilstein 5100's
Lifted and locked
07-22-2014, 06:38 PM
#71
Funny you mention that. I just put one if those on order. 4wheel parts said they were 3-4 weeks out on production.
My Build Thread!!
07-23-2014, 10:54 AM
#72
You will have to let me know what you think of it and how it fits once you have it??? Very curious.
One of the guys from my local wheeling club has started selling Comeup winches. He thinks this is a killer product:
Amazon.com: Comeup 299372 (Seal 9.5i) 12V Winch: Automotive
I want to see if it can be broken down enough to fit behind the stock bumper as well. Realistically my XRC8 is still in fine shape so I'm probably a couple years out from swapping winches. May just switch it over to synthetic and call it good.
Bilstein 5100's
Lifted and locked
07-23-2014, 01:20 PM
#73
I will post pics in here and in my build thread as soon as I get it installed for sure!
I know that it will look cleaner for sure with the synthetic line and the hawse fairlead instead of the roller one.
My Build Thread!!
06-09-2019, 08:32 PM
#74
You made my day!
Been looking for a reasonable winch mount for my 96 - this is it! Winch arrives next week (HF Badlands 12000) with the mounting plate. Can't wait to get after it. Thanks for the great post and great pics!
06-10-2019, 08:16 AM
#75
I sure am glad to see that this is still helping people to this day. I have since moved onto a Tundra that I have lifted and put 20's and 35's on I do miss my 4runner sometimes cause i could just run through the woods with it if i wanted. I had a Honda Pioneer 1000-5 for a little while as my 4runner replacement but sold it cause we didnt use it much. Now however I got back into a very capable suv and got my wife a 2016 Lexus GX460, not sure if we will take it into the woods just yet however we do have many plans for it in the future. look forward to seeing that badlands 12000 mounted up.
My Build Thread!!
