Originally Posted by Myjar89
I believe my 4Runner is cable driven? We just replaced throttle cable and transmission cable. The 4Runner is running terribly after these cable replacements. Surging at idle and hesitation when pressing gas pedal
Are you sure you have an 01? Sounds like you have a 2000 then.
The cable should not have any slack or play, but the throttle valve needs to be shut 100% when you let off the gas. Is it routed correctly and not being pinched?
You replaced the transmission cable though? I wasn't aware that 2000 have a transmission kick-down cable. Are you sure it wasn't the cruise control cable?
