Old 01-17-2020, 12:47 PM #61
robb1887's Avatar
robb1887 robb1887 is offline
robb1887 is on a distinguished road
robb1887's Avatar
I didn't realize people were still following along. Yes! stuff if still happening, slowly but surely. Not so recently anymore but we got news we're expecting come April so I ended up having to rearrange some schedule and ended up buying a new 2020 Tacoma double cab and am currently selling my 2003 Xtracab.
Since the last update though a lot has happened.
Test fit the motor/trans location in the body:
Got the exhaust mostly figured out:
Deleted the SAP system and hid some of the electronic controlled valves that get "checked" on system start up:
Filled in the hole where the headers interfered with the strut tower:
Got my 4x Innovations sliders powder coated to match the FN Wheels pretty darn good:
Ordered replacement brake and fuel line and fabed a DIY straighener:
Test fit the Aussie Diesel Radiator and made up the Rad and PS lines:
robb1887 is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 09:09 PM #62
robb1887's Avatar
robb1887's Avatar
Plumbed in the intake and welded in the mounts, also filled the old boxed holes
Then the weather was junk for a few weekends so I decided to do my diff builds/rebuilds. Front was just a rebuild for 4.10s, new bearings, and electronic selectors. Rear was elocker 4.10 retrofit, new bearings and axle housing work and panhard bar lift.
Also started my crib sheets for the wiring
Old 05-08-2020, 10:41 PM #63
robb1887's Avatar
robb1887's Avatar
This is going to a buddy's to get milled down tomorrow
Old 05-29-2020, 03:46 PM #64
robb1887's Avatar
robb1887's Avatar
Axle housing getting buttoned up soon
Cleaning it up after the machining and welding
Testing the locking actuator
Making new lines
Recoated
Together
Locked and unlocked
Https://i.imgur.com/51CyHIf.gifv
Imgur
Old 05-29-2020, 04:46 PM #65
I had a theory that radiator would work... glad to see it does.
How much body lift did you used for that much hood clearance? What vehicle was your donor from? I see the 4Runner airbox, but what about the rest?
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-29-2020, 10:05 PM #66
robb1887's Avatar
robb1887's Avatar
Using a 2006 Tundra drive train.
Zero body lift with custom motor mounts.
Old 08-01-2020, 08:29 PM #67
robb1887's Avatar
robb1887's Avatar
Post
Radiator shroud got bent up and corners welded from a buddy's friend. Gonna need some tweaking to fit better it's tight right now
Old 08-03-2020, 10:04 AM #68
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Man that's a squeeze! What are you going to do about the fan? Doesn't look like you have enough room between the shroud and accessory drive/hoses. Going to mount a pusher on the inside of the shroud forcing air out toward the motor?
Old 10-27-2023, 09:47 AM #69
robb1887's Avatar
robb1887's Avatar
As apparent from my ghosting of this thread, the project lost steam when life changed, kids were born and projects shifted priorities. I've been considering letting this project go to a new home in it's current state, with my certifiable amount of spare and "in case" parts I stashed from the donor tundra and various u-pull-it parts hoarding. Even if I were to finish this to a running state, I just don't see how it fits into my vehicle line up future state and would prefer to let someone enjoy it and hopefully finish what I started.
If I cannot sell it together, I may part out the pieces but prefer a complete sale for my health and my wife's sanity.
I need to get a full inventory of everything I have, but I tried to update the 1st post to include it's current state
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
Where is the huge thread about the drive shaft clunk? TeryT 4th Gen T4Rs 5 02-25-2010 01:32 AM
